Thread: Rear subframe removal
    Mar 2017
    newcastle
    Vehicle : Insignia
    Trim : Exclusiv
    Engine : 1.8 vvt
    Mileage : 90000
    Default Rear subframe removal
    Hi ppl. Just wanted to see what's involved in removing the rear subframe on my 09 1.8 hatchback. Many thanks
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    look in the diary of dog_book you'll see the complete dismantling and re-assembly.
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    I’ve not fully updated it yet but there were snippets posted in other areas for all to see. Might be slightly different though as the OP has an insignia as opposed to a Vectra but can’t see a massive difference only in shapes and handbrake mech as they use motors.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Regular Member JagRigger's Avatar
    Norfolk
    15 Post(s)
    Engine : 1.8 VVT ( No2 ! )
    Mileage : 310 k !
    Not too bad a job depending on what you are swapping over - I tried to remove the hubs to change the dust shields and killed the ABS on both as they were seizes and didn't take kindly to a lump hammer
    Mar 2017
    newcastle
    Vehicle : Insignia
    Trim : Exclusiv
    Engine : 1.8 vvt
    Mileage : 90000
    I'm just doing a bit tidy up. Start at the back and work forward. The fronts no bother just never done the rear sub before.
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    i pulled up a picture yesterday of the rear subframe on an insignia.. it does look a bit different but has about the same amount of bolts to be removed so basically it will be the same job... bar the different layout of a few of the components so bolt will be in a different location.
  1. SAAB 9-3 rear subframe
    By JagRigger in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2020, 18:46
  2. Signum 2005 Lowering Subframe and Steering Rack Removal
    By Poolballboy in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2016, 19:48
  3. rear subframe ?????
    By cpt slow in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2006, 19:59
https:www.vectra-c.comforumshowthread.php237072-Rear-subframe-removal
https:www.vectra-c.comforumshowthread.php237072-Rear-subframe-removal#::text=i pulled up a picture Navigation Suspension Wheels & Brakes Tophow do you remove the subframes from a 2007 saab 9-3
