Thread: Opel Vectra C 2003 AC Module (buttons) problem
    Apr 2021
    Greece
    Vehicle : Opel Vectra C 2003
    Trim : Elegance
    Engine : 1600
    Default Opel Vectra C 2003 AC Module (buttons) problem
    Good afternoon everyone.
    I bought my vehicle about 3 years ago as i was looking for a family car and the price was very good. (Opel Vectra C 2003 1600cc Elegance).
    Since day 1 i bought it i couldnt figure out how to change where the air flows when the ac is on. I looked online and figured out that i need to press to central button to enter the ac menu. I am pressing it but nothing appears on the screen. I need to replace the module, or is there any other trick to make it work?
    btw, my ac module is the 2 zone ac.
    Any help would be greatly appreciated.
    Thanks in advance!
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    the first thing to do is have the car readout as this problem will leave an error in the module... to save you a headache find a place that has the right tool to read out the module (tech2/GDS or O./V.com)
    Administrator plasma's Avatar
    On the Forum
    579 Post(s)
    Engine : 150
    Mileage : 74000
    quite common for the centre buttons to fail, they tend to work best once warm with a good press.... you can replace it with another, but will need the 'variant configuration' setting up...
    as a fix IF it is the control module you can take them apart and reflow the solder on the 6 pins (i think it is) on the rotary dial
    but as northpole says, get a code reader on it first to see if you have an errors
    Apr 2021
    Greece
    Trim : Elegance
    Engine : 1600
    Quote Originally Posted by northpole View Post
    So if i understand correctly, there is a tool that can read if there are any errors with the module. I suppose its different than the obd2 port. Whats the name of the operation or the tool needed so i can find one in my area?
    Apr 2021
    Greece
    Trim : Elegance
    Engine : 1600
    Quote Originally Posted by plasma View Post
    So if i replace the whole module, i need to configure it somehow so it can be red by the car?
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    well no the tools i named work via the OBD2 port the problem is GM/Opel/Vauxhall (and all their daughter brands) need to be connected with a certain multiplex cable... tech2/GDS is what the dealer uses in most cases... O./V. com is another way of having almost the same functionality to readout all the modules and fault codes on these cars... but they all work via the OBD2 port....
    yes if you get a replacement, it needs to be de-coded (un-married) from the car it came from, or replace it with a new un-coded one, than it has to be coded to your car... (you will need the passcode to the car so if you don't have that you can obtain it from your dealer)
    So if you can solder, try to fix yours as that is and will be the easier and cheaper solution...
    Apr 2021
    Greece
    Trim : Elegance
    Engine : 1600
    Thanks a lot!
    one last question. This rotary dial that has the problem, is also responsible for manually adjusting the fan speed. Turning it right and left works. The only issue is when i am pressing it for the menu to appear. Does that makes any sence? And is it consistent with what you guys know?
    Regular Member Jon1796's Avatar
    Sep 2015
    Norwich
    30 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    the panel is one of only a few modules that doesn’t need a pin as it doesn’t have vin in only needs can/config for the car it’s going in. If it was Astra zaffy you can rewrite/program for it to fit each vehicle.
    On the Forum
    579 Post(s)
    Engine : 150
    Mileage : 74000
    as per jon on this one.. doesnt need a code, but does need to be included on the midspeed canbus if changing any of the radio/display/bluetooth units
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    I'm not that clued up on the module (as i have manual airco) but with his car being a half-canbus it might be stubborn accepting changes or rejecting stuff for no reason at all... as I found out with my car when I tried to activate the electric rear windows... it didn't accept the drivers multi-function switch at all had to get another one with a different code on it and it worked... for me that was a first ever as i've never experienced that on any car.
  1. Android in Opel Vectra 2.2 Elegance - 2003
    By EnemyUnit in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2021, 11:17
  2. holden/opel vectra c 2003 2.2
    By Chopper14 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd November 2018, 22:37
  3. Buttons on wheel to control on board computer on Vectra C 2003
    By riahc3 in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2013, 19:58
  4. OPEL VECTRA 2003 - CDR 2005 Unit
    By Tigra16V in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 21:02
