Thanks Thanks:  2
Likes Likes:  12
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Windscreen Washers not working
    Jan 2008
    ESSEX
    Default Windscreen Washers not working
    2008 VECTRA C, windscreen washers both front and rear have stopped working. Can hear the pump working when stalk is pulled.
    Removed the pump and water poored out so presume filter isnt blocked. Headlight washers are working. There is no water dripping from under car when the pump is operated so presume no pipe has come loose.
    Are the pipes to back and front in anyway linked? As that could indicate blockage I suppose.
    Would appreciate any guidence as at a bit of a loss unless pump is knackered but does not sound as though it is. TIA
    Regular Member Jon1796's Avatar
    Sep 2015
    Norwich
    30 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Disconnect pipe from pump, yes it’ll stray all over the place get other half to activate wash while thumb over end to see if wash pump is pushing water through.
  3. Thanks jimhammer thanked for this post
  4. #3
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    What he said... had this problem a few times... was the pipes being blocked somehow... what i did was remove the pipes from the jets than blow them through with compressed air... reconnected it up, put compressed air through the nozzles, than put the pipe back on the pump... go and test and after a few seconds they work as normal... oh and i hope you've upgraded your washer jets to the insignia mist jets... they work way better and need less washer fluid to clean the windscreen.
  5. Thanks jimhammer thanked for this post
  6. #4
    Dec 2011
    ESSEX
    Finally got round to trying to sort the problem, took pump out (part no 90508709) as was not pumping when stalk operated. But not sure I have the right pump as when I operate the stalk there is the sound of a pump still operating!
    Are there 2 pumps (in vxr) as I wonder if the one I have taken out is just for headlamp wash.
    TIA
    jim
  7. #5
    Regular Member JagRigger's Avatar
    Norfolk
    15 Post(s)
    Engine : 1.8 VVT ( No2 ! )
    Mileage : 321 k !
    90508709 is the headlight wash pump. Screen is 90585762. If you have headlight wash you will have both. Headlight was should only work every 4th pull of the stalk, or after a delay ( 2 mins from memory )
  8. #6
    Dec 2011
    ESSEX
    Thanks for info, got to locate other pump now! Hopefully its near the other one save pulling the bumper.
  9. #7
    Norfolk
    15 Post(s)
    Mileage : 321 k !
    They are - be playing with mine tomorrow as I've lost headlight wash
  10. #8
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    I do wonder sometimes why i bother taking pics and explanations in a car diary.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  11. #9
    Jan 2008
    ESSEX
    Dog_Book I would love to read your car diary, but where is the link? I am sure I have looked in the past without success.
  12. #10
    13 Post(s)
    Quote Originally Posted by Dog_Book View Post
    Do you have one then? You kept that quiet
  1. Windscreen washers stopped working
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 18:10
  2. windscreen washers
    By bigsteve2255 in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2011, 23:08
  3. Windscreen Washers
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2010, 22:04
  4. Windscreen Washers.......
    By david.aka.judas in forum Bodywork & Interior
    Last Post: 16th December 2008, 23:25
  5. windscreen washers
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2008, 19:04
