7th February 2021, 21:52
#41
Originally Posted by
AndySignum2.2
I did think the f5r would be a better choice......however, if it is the petrol that has caused this, then, all the other petrol lines will need to be checked sooner rather than later. Could I bypass the high pressure fuel pump with an inline one? would that be easier/more difficult/fiddly?
Er no
8th February 2021, 16:30
#42
troutybrown
Er no
Thought I would ask....just in case....my brother thought it might be possible.
8th February 2021, 17:02
#43
AndySignum2.2
The issue with the ethanol is not in the supply but once put under high pressure within the pump and pipes from pump are steel.
8th February 2021, 19:25
#44
troutybrown
I read some about it, that's why I posted that link in a previous post and I don't think vauxhall have fixed the issue tbh......after all the car had it replaced in 2010, its only done 59k miles and its ******ed again?
10th February 2021, 13:10
#45
Cleared faults to start again and this time.......
P1191 - Fuel Rail Pressure Sensor Circuit Low Input
(5A) - Present
So is it still the HPFP?
10th February 2021, 13:49
#46
what pressure is it reading on the fuel rail... if it is below 6 bar or 600kpa you might need to replace the sensor or the pressure release valve at the end of the pump might need replacing, but that is a might .. in most of these cases the owners end up replacing the expensive fuelpump... it is one of the reasons why i would never get a 2.2 petrol from GM every model that has that engine has that problem going back to the frontera and even the isuzu montery with these engines have the same problem...
ps low pressure side of the pump should be 3.4bar or 340kpa with the engine running... so if the pressure is way of well erhmmm mate just replace the whole thing with a new one.
10th February 2021, 15:54
#47
Need to check live data.
Desired fuel pressure and Actual fuel pressure. Actual should follow Desired as you rev the engine.
https://www.youtube.com/watch?v=J6x4_9nOMFs
Dan will explain
10th February 2021, 16:55
#48
yeah i know about requested vs actual needing to be really close... if they aren't something is deffo gone...
I'm not going to watch the video as to be fair i would've already bought a new pump and replaced the lot... i know it's expensive but i hate the guessing game.. although diagnostics can help i rather replace than take the old one apart to see if it can be salvaged... at least that way i got a running car and just maybe a spare...
10th February 2021, 18:25
#49
troutybrown
where did you dig that up from good vid save as you’ll be needing that plenty more times.
10th February 2021, 18:47
#50
Jon1796
He does a load of them his fuel trim ones are worth a look very knowledgable guy.
