Thanks Thanks:  6
Likes Likes:  7
Thread: Alternator Not Charging
    Feb 2019
    GLOUCESTER
    Engine : 3.0 diesel
    Default Alternator Not Charging
    Hi All, I am after some ideas. The alternator on my Signum 3.0 V6 CDTI isn't charging. It has been replaced, the garage tells me there is no difference with the new one, so it is very likely something else causing it.
    Anyone have any ideas? Thanks in advance
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    It's a garage they need to do some diagnostics... let me say it this way if i was to bring my car into a garage and they wrongly diagnose this resulting in me changing the alternator, just for them to tell me it's not that i would loose my ****... 9 out of 10 times it means the auxiliary belt tensioner needs replacing( plus the belt itself) and if the can't find that out by themselves that is one bad garage... i'm not even a mechanic and know that this is one of the problems with the belt tensioners on most cars... it is the first thing they should've looked at anyway plus they should've tested the output of the alternator before replacing it...
    I would say find another garage...
  3. Thanks daveystoat thanked for this post
    Likes Vwdub2000, nikroc liked this post
  4. #3
    Regular Member Jon1796's Avatar
    Sep 2015
    Norwich
    30 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Plug a diagnostic’s in and look on engine to see if canbus is reading anything. Also check continuity of cables to from alternator to battery.
  5. Thanks daveystoat thanked for this post
  6. #4
    Regular Member Vwdub2000's Avatar
    Apr 2018
    Scotland
    Vehicle : Vectra c estate
    Trim : Life
    Engine : 1.8
    Check the basics the wiring, ground wire, positive wire use multimeter, clean up and check contacts that run back forth between alternator and the battery. It's older car add British weather more issues. That is where I would start.
    Sent from my SM-N960F using Tapatalk
  7. Thanks daveystoat thanked for this post
  8. #5
    Feb 2019
    GLOUCESTER
    Engine : 3.0 diesel
    Ok, thanks for the replies. It was the AA who diagnosed the alternator as faulty, not the garage. They have put a new alternator on, and it hasn't fixed the problem, they don't think it is the tensioner (the tell me there is no play in it and the belt is fine, that is only about six months old anyway).
    They are waiting on their auto electrician to have a look at it, I just thought I would see if anyone had any ideas/experience on it here.
  9. #6
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    Will be wiring to and from the alternator that causes the problem than... like I said some simple checking and a multimeter would do the trick...
    They don't need an electrical guru for that.
  10. Thanks daveystoat thanked for this post
    Likes daveystoat, nikroc liked this post
  11. #7
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    Having similar problems with my 1.9cdti Astra twin Top . Battery keeps losing charge if left for 3 days .Now the heating has packed up , no blowers . Temp gauge showed minus 32.6 ,now just F .
  12. #8
    Sep 2015
    Norwich
    30 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Quote Originally Posted by soulman View Post
    on that I’d check uec and bcm. From what I’ve read damp or corrosion on pins on back of uec, or failure of bcm.
    silver kept draining the battery since I got her then when I added rain sensor to blacky and turned on comfort close blacky had same thing so turned off on both now fine.
  13. Thanks soulman thanked for this post
  14. #9
    Feb 2019
    GLOUCESTER
    Engine : 3.0 diesel
    This is, finally, sorted out. Turns out it was the ECU not telling the alternator to operate, apparently because damp got into it. The ECU has been repaired and all appears fine now.
  15. Likes Vwdub2000 liked this post
  16. #10
    Apr 2018
    Scotland
    Trim : Life
    Engine : 1.8
    Quote Originally Posted by daveystoat View Post
    That's great, happy you got it sorted. Good diagnostic is key.
  17. Thanks daveystoat thanked for this post
    Likes daveystoat, northpole liked this post
  1. Alternator charging at 12.6 volts
    By Beardy in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2016, 13:05
  2. Alternator charging
    By birdii in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2015, 14:10
  3. Battery not charging. Alternator???
    By 123rado in forum Engine & Drivetrain
    Last Post: 12th May 2013, 14:18
  4. Charging issue , maybe alternator or not
    By kman247 in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2012, 17:44
  5. Alternator not charging?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 2nd May 2011, 13:15
