Thanks Thanks:  1
Likes Likes:  5
Results 1 to 10 of 18
Thread: Coolant pipe
    Nov 2016
    Orkney
    Trim : SRI Estate
    Engine : 1.9 cdti
    Default Coolant pipe
    Hi with my down time I thought I'd get round to fitting new EGR cooler and the metal coolant pipe that runs along the front of the engine . A couple of questions if you don't mind 1 I've got a new gasket for the coolant pipe is it advisable to use any sealant on it ?, 2 does anyone know what thread the bleed screw is ? don't like those plastic things . cheers and all keep well
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    45 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    you could remove the bleed screw on the new pipe and check the thread yourself and compare it to whatever bolts you have laying about... but it's plastic for a reason... basically so you don't damage the metal pipe upon closing it.
  3. Likes norse liked this post
  4. #3
    Nov 2016
    Orkney
    Trim : SRI Estate
    Engine : 1.9 cdti
    Quote Originally Posted by northpole View Post
    I did check my bolt store and can't find any the right size
  5. #4
    Apr 2016
    Ipswich
    45 Post(s)
    Mileage : 140000
    In that case leave it be.... it actually saves the drain plug from being over tightened thus rendering your metal coolant pipe useless...
    One tip I will give you though... get some metal paint and protect the pipe from outside rust it'll also look better
  6. Likes norse liked this post
  7. #5
    Nov 2016
    Orkney
    Trim : SRI Estate
    Engine : 1.9 cdti
    it's stainless
  8. #6
    Apr 2016
    Ipswich
    45 Post(s)
    Mileage : 140000
    I've seen stainless rust... the only version of stainless steel that is harder wearing is polished stainless steel...and left long enough even that starts rusting.. I would paint it period but it is up 2 you. And why it trusts is simple it still has iron in it as a core component..
  9. Thanks norse thanked for this post
  10. #7
    Nov 2016
    Orkney
    Trim : SRI Estate
    Engine : 1.9 cdti
    why not , better to do it now while it's off
  11. Likes northpole liked this post
  12. #8
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    295 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Yes and varying amounts hence most stainless has a lower tensile strength than others, if I remember correctly it’s a higher chromium content that stops corrosion. The only corrosion I ever saw on my stainless coolant pipe was from the bronze brazing that joins its components together.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  13. Likes norse liked this post
  14. #9
    Apr 2016
    Ipswich
    45 Post(s)
    Mileage : 140000
    Quote Originally Posted by Dog_Book View Post
    Yeah but you keep your car and engine clean... and if you spot something like rust you replace the lot...
    Like I said if left long enough it'll rust...
    I have painted a full stainless steel downpipe with heat resistant enamel paint just to find it rust anyway... but that was on a daily mk4 golf gt tdi... it saw all kinds of weather... rust was on the downpipe after 8 years of daily abuse ( I say abuse because I managed to drive that car from 70k to 472.5 k, it was with relayed travel anyway, i used to work as a mctip ict network specialist consultant, sorting out network problems all over the UK)
  15. #10
    Nov 2016
    Orkney
    Trim : SRI Estate
    Engine : 1.9 cdti
    Sorry back again about to start this job tomorrow ( I'm assuming the new gasket doesn't need any sealant ) while getting ready to start I noticed the wiring connector for the cooling fans slide out clip is broken , there's nothing to pull out to release it does anyone know of a way to get it off ? with out destroying it !!IMG_0019_LI.jpg
  1. egr coolant pipe bolts
    By got3dogs in forum Vectra C / Signum Troubleshooting
    Last Post: 6th February 2019, 06:36
  2. For Sale: Coolant bleed screw, genuine for front coolant pipe most engines
    By Dog_Book in forum Parts for sale
    Last Post: 20th April 2017, 19:01
  3. Coolant pipe.
    By woodspsx1 in forum Engine & Drivetrain
    Last Post: 12th February 2015, 17:06
  4. Which is the better coolant pipe?
    By Chunklamb in forum Engine & Drivetrain
    Last Post: 8th April 2014, 07:14
