Thanks Thanks:  5
Likes Likes:  5
Thread: Power steering fluid loss
    Nov 2010
    Shropshire
    Vehicle : Insignia Ecoflex
    Engine : 2000 diesel
    Year : 2013
    Default Power steering fluid loss
    My sons Vectra C power steering has got intermittently heavy and when he checked the level of the fluid it was way below the dipstick. There are no signs of leaks so I was wondering if there may be some other known fault or reason for the fluid loss?
    Jan 2016
    buckley
    8 Post(s)
    Vehicle : vectra
    Trim : design
    Engine : 1.9 150 diesel
    Year : 56
    check the gaiters on the stering rack,the seal goes with no visable fluid leak
  3. Likes heraldsteve liked this post
  4. #3
    Sep 2019
    Bedford
    Trim : SRI CDTi 150
    Engine : 150
    Default Power Steering Leak
    When I bought my Vectra, I had a once over from a trusted garage (after the event...doh) and they identified a leak on the underside about 1 ft from the wheel (on axle?). They said this was the powersteering fluid and a worn/faulty joint/seal, and would cost 300£ to sort (they said they couldn't just replace the seal).
    There was no issue with the feel of the steering and the level was OK. After about 6 months, the steering felt heavy - it came on quite quickly. I topped it up and all was fine again. I top up about 1/2 litre every 6 months. On a 10 year old, 150K car it wasn't worth spending that amount of money. No issue passsing the MOT either apart from an advice.
    My point is that that the heaviness didn't come on gradually.
    Cheers, Ian
    Quote Originally Posted by heraldsteve View Post
  5. Thanks heraldsteve thanked for this post
  6. #4
    Sep 2014
    uk
    Engine : 1.9 cdti 150 x 3
    Year : 08/07
    You dont say what model of vec BUT if there is no sign of a leak i would syringe out the old oil thats in the reservoir and then refill with the correct oil to the correct level and see how it go's.
  7. Thanks heraldsteve thanked for this post
  8. #5
    Oct 2015
    East Yorkshire
    Vehicle : Vectra c
    Trim : Club
    Engine : 1.9cdti
    It will come on suddenly as as soon as air gets drawn into the system the steering will become heavy as air is compressible and fluid is for all intents and purposes not. Keep on topping it up while the seal leak isn’t too bad. You’ll know when it’s too bad, you won’t be able to keep fluid in the system.
  9. Thanks heraldsteve thanked for this post
  10. #6
    Sep 2018
    Herts
    17 Post(s)
    Trim : Best
    Engine : 2.0T
    Year : 2008
    I had the same issue on mine, I solved it with a stop leak product from Halfords (can't remember the name) and it worked a treat. Power assistance was returned as soon as I refilled the PAS bottle.
  11. Thanks heraldsteve, big jon thanked for this post
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Which power steering fluid ??
    By FatboySteve in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2011, 10:07
  3. Power Steering Fluid Top-up
    By APJ in forum Engine & Drivetrain
    Last Post: 26th May 2009, 01:52
  4. Power steering fluid
    By steven_armit in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2008, 22:24
  5. Power Steering Fluid
    By MLC in forum General Chat
    Last Post: 28th June 2006, 13:09
https:www.vectra-c.comforumshowthread.php235237-Power-steering-fluid-loss
vectra c steerng oil leak
