Results 1 to 5 of 5
Thread: Clunking on gear change - Engine/Gearbox Mounts?
    Regular Member Tyler Durden's Avatar
    Oct 2018
    Shrewsbury
    Engine : 2.0T
    Default Clunking on gear change - Engine/Gearbox Mounts?
    I have a slight clunking on gear change. If I make the car labour by selecting too high a gear it clunks A LOT!
    I think I need to replace my engine and/or gearbox mounts. Is there a how to on this?
    Also, where would I find the right parts?
    TD
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    autovax, dealers parts counter, eBay or universal places like ECP, GSF, Jayar etc, etc. You actually don't need an how-to for it, if you want to remove a mount, you look at where it is make sure you put a jack under the engine on that particular side, than you replace it... it is that simple.
    Oct 2018
    Shrewsbury
    Engine : 2.0T
    I still have not got round to doing this. Has anyone here done it? Is it as easy as that? .
    Regular Member Jon1796's Avatar
    Sep 2015
    Norwich
    30 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Yep!!!
    Bottom mounts anyway.
    And so long as top mounts are sound that’s where it holds engine weight the bottom 2 stop rotation and can be taken off ten minutes for front half hour rear as you’ve got to drop flexi (well on z28net).
    Can be done without jack but that’s up to you!!!
    Oct 2018
    Shrewsbury
    Engine : 2.0T
  1. Y30DT engine and gearbox mounts
    By BigWilko in forum Y & Z30DT Specific
    Last Post: 27th August 2018, 18:15
  2. For Sale: Powerflex gearbox / engine mounts - Vectra c and Signum
    By Caveman_nige in forum Parts for sale
    Last Post: 3rd March 2013, 11:31
  3. engine and gearbox mounts
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2011, 19:35
  4. Help! Engine Gearbox Mounts 53-3.2 V6 GSI Vectra
    By garygsi in forum Engine & Drivetrain
    Last Post: 7th February 2011, 20:18
  5. Engine / Gearbox Mounts 2.2 DTI
    By MJL in forum Engine & Drivetrain
    Last Post: 20th October 2009, 12:43
