Results 1 to 3 of 3
Thread: reuse the oem gps antenna?
    Nov 2014
    Sunderland
    Vehicle : Vectra C
    Engine : 3.0 V6 CDTi
    Default reuse the oem gps antenna?
    im wondering if anyone knows if you can make use of the gps antenna built into the car if you previously had a cd70 navi on an aftermarket head unit - my clarion unit has the same color and connector for the gps antenna but i would have to purchase a fakra extension as the right angle connector on the cars loom will not connect to my head unit due to the fakra connection being recessed,
    just curious as it would save me running a gps antenna if it can be used.
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    all GPS aerials are the same so if you can get a fakra extension than get it... the difference is in the hardware chip that is in the radio. And i haven't seen a difference yet in the aerials that are used in cars if they are wired... when they connect wireless (usually over BT) than the aerial has the chip in it and than it makes a difference concerning location accuracy and how fast BT the system connects to the hardware in your headunit... ( bt- protocols, and the GPS hardware chip protocols are a factor here)
    Nov 2014
    Sunderland
    Vehicle : Vectra C
    thats that will make my install a lot more tidy although im still having to run 3 antennas anyway (DAB, and 2 amplified TV )
  1. dab antenna
    By skeggylad in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2018, 18:26
  2. Can I reuse parking sensors?
    By iani in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2011, 09:44
  3. Anyone got the VXR antenna
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 00:16
  4. Sat nav gps antenna
    By bigmac in forum Parts for sale
    Last Post: 22nd March 2009, 12:49
  5. Ext antenna
    By blr123 in forum General items for sale
    Last Post: 6th January 2006, 16:07
