Thread: Nearside indicator out, but bulb tested and working. Can headlight be dismantled?
    Apr 2011
    Norfolk
    Default Nearside indicator out, but bulb tested and working. Can headlight be dismantled?
    As titled.
    Nearside indicator had failed. I had the headlight out and unplugged it, took the bulb holder and bulb out. Put 12v across the bulb holder and it lit up.
    Put it all back together and or was fine for a few days then went again.
    Have again removed bulb and bulb holder. Bulb was stool fine but changed it anyway. Also tested the supply to the headlight unit, this was fine. So now I'm stumped. There must be a fault inside the headlight unit.
    Can it be dismantled or do I need to start thinking about replacement?
    I have some bi-xenon HID custom-built so replacement will be last resort. I was also thinking about rigging up a relay taking a feed from the side repeater to drive the bulb holder using some repair wiring to direct to the bulb holder, and a canbus suppressor on the original supply.
    Arghhhh!
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    66 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    clean the UEC with an electrical contact cleaner... i had this problem with mine but mine was the hid's or the fog-light on the OS that acted up ... I cleaned the UEC and i never had the problem again
    Apr 2011
    Norfolk
    Okay, I'll look into that. Just to check - UEC = Under-bonnet Electrical Centre?
    New Member bibu16v's Avatar
    Oct 2021
    Timișoara
    Trim : SW Elegance II Sapphire Black
    Engine : Z18XER
    Mileage : 155k km
    UEC - Underhood Electrical Centre: located, for Vectra C, on the left side front wing, near the battery, under the hood/bonnet.
    REC - Rear Electrical Centre: located, for Vectra C, on the left side rear wing, in the trunk/boot.
  1. front right indicator bulb not working but flashing fast
    By Craiganvec in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2017, 20:37
  2. fast flashing N/S indicator although bulb is working fine
    By ukgofer in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2016, 17:39
  3. Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 19:20
  4. Changing the Nearside headlight bulb
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 21:01
  5. Headlight indicator bulb holder...
    Last Post: 8th September 2006, 20:27
