Thanks Thanks:  3
Likes Likes:  10
Results 1 to 10 of 19
Thread: F40 automatic gearbox oil cooler
    Regular Member Bigestly's Avatar
    Mar 2014
    Kent
    Trim : SRI
    Engine : 1.9 CDTI 150BHP
    Default F40 automatic gearbox oil cooler
    Hello,
    Today recieved the gearbox oil. Quite a good price from Autovaux Cooler ready to be fitted. Have the pipes as well. I know that some members have been fitting the gearbox oil cooler on their Vectra/Signum. Maybe somebody could share diagrams or any info how to fit it properly? Had reccommendations do not connect it straight to the gearbox.
    Thank you
    Išsiųsta naudojantis SM-G925F Tapatalk 4 Lt
  2. Thanks kantimpalo thanked for this post
    Likes kantimpalo liked this post
  3. #2
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Mileage : 101000
    I connected the same cooler, directly to the box, using lengths of rubber pipe between the ends which used to go into the rad-end cooler. No issues thus far..
  4. #3
    Mar 2014
    Kent
    Trim : SRI
    Quote Originally Posted by Teapot View Post
    Saw your one pal...idea to fit the cooler came from your reccommendation after remap
    I'm collecting info how to do it because the job wouldn't be done by myself and want to do it properly, provide details for the garage. Will be getting Haynes manual...maybe there will be something interesting to read
  5. #4
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    If a garage with qualified and experienced staff can't work this out themselves you'd do a better job yourself, I'd expect the garage to tell ME how to fit it.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  6. #5
    Mar 2014
    Kent
    Trim : SRI
    Quote Originally Posted by Dog_Book View Post
    I'm sure that they will figure it out, but it's always better to provide more info for the job like this. Not a simple oil change done by themselves hundreds of times
    Another thing...nothing covered about this oil cooler on the forum or my search skills crap Most of us knows the issue that the engine coolant sometimes gets to the gearbox and damages it. Costly repairs follows after it.
    If I dig more details out I will post it for sure and I hope somebody else will have better idea how it works to retofit the gearbox oil cooler
  7. #6
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Well from what teapot said it sounds dead easy, all they need to do is securly mount it so it gets air flow. Then using new hose connect up to the box, as I've never looked at these I assumed they had special fittings on the ends as last time I did this on a 4x4 I had to have the correct length hoses made up by Pirtek.
  8. #7
    Mar 2014
    Kent
    Trim : SRI
    Did you used these pipes?
  9. #8
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Mileage : 101000
    No I didn't use them. All I did was jubilee clip 10mm hose to the pipe ends which used to go into the radiator, and extend up to to the new cooler.
    The pipe pictured includes an in-line thermostat, to prevent fluid passing through the cooler until the fluid is hot. It would be a nice addition if you can veriy it works. Mine looked a bit corroded, so I decided not to use it and just plumb direct.
  10. #9
    Mar 2014
    Kent
    Trim : SRI
    I was thinking what's that thing on the right side of the pipe...it's thermostat, but not sure how you can verify if it's working. Doesn't look rusty and no any plugs on it that temperature could be observed. Probably worth to check just blowing some compressed air through it...see if not blocked.
    Going to fit it tomorrow. Fingers crossed
  11. Likes Dog_Book, Teapot liked this post
  12. #10
    Mar 2014
    Kent
    Trim : SRI
    Gearbox oil cooler fitted Couldn't use original hose as the gearbox inlet/outlet ports in a different place. Just disconnected current one from the radiator, bit bent upwards and some black hose for extension till the cooler. Drained all the oil ( well...about a half of it not splitting a gearbox ) and 3l new one gone in.
    At the same time front sri springs fitted. No more lifted front with springs from V6 vectra
    Also fitted new rear tyres as the one had a splitted side wall. Another had a screw in it and air was leaking.
    Been quite a good day, but everytime on repairs new things spotted and placed on the jobs to do list
  13. Thanks dazmufc, kantimpalo thanked for this post
    Likes Teapot, Dog_Book, dazmufc, kantimpalo liked this post
  1. Replies: 7
    Last Post: 4th November 2015, 08:37
  2. Automatic box oil cooler
    By mythnmagic in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2015, 17:29
  3. Replacement for the auto gearbox cooler
    By Lao in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2011, 15:12
  4. Automatic Box oil cooler
    By Big Bri in forum Engine & Drivetrain
    Last Post: 5th September 2009, 17:58
  5. Automatic gearbox oil and cooler info required.
    By m0cea in forum Engine & Drivetrain
    Last Post: 21st September 2008, 00:05
af40 oil cooler
oil for automatic transmission opel antara 5 speed
opel vectra c 1.9 cdti automatic gearbox cooling pipes
vauxhall insignia automatic gearbox oil pipessaab 1.9 tid automatic gearbox oil coolertransmission oil zafira b
