Has any of u guy used this product the reviews look real good.. what's your opinion..B06BA3FE-9869-417B-AD53-952A6D382571-8085-0000087D9E019B5B.jpeg
Sent from my iPhone using Tapatalk
Mike @MCD been very pleased with it
all the help you after can be found here.
Vectra SRi estate 165/230 CDTI 2006 XP
Stret & Teapot tuned, fully blanked and deleted EGR, Precat & DPF deleted, FMIC, Silicone & alloy boost pipes, 4 bar TMAP Sebastian 56 small 7 blade turbo & 2.0 Injectors
slightly different stuff , aldi have some waterless ,wax and polish in 750 ml trigger bottle ,with microfibre cloth ,2.99 its got carnuba wax in it, the shine is very good,and water just beads off car ,lasts a while after application ,cant recommend it enough ,I've bought 3 in case it disappears like it did last time
Thanks for the tip i will get me some i ran out of my waterless wax and polish... i used demon shine and it's good but kinda expensive it also has carnuba wax in it and it lasts about 2 months and that is with a weekly wash with normal car shampoo. But i did see it and thought it wouldn't be any good but now that you've mentioned it i will go and get it today.
Its amazing stuff... but personally, only apply it after full correction and a few layers of decent wax.
Then the muck litterally rinses off...
Yeh, you need it soft. So clay, tar remover if necessary. Then ideally a mild cut.... good polish, top resin then this stuff to seal. It will work on slightly rougher paint.. but is a ***** to buff up then. I also use a DA... which is a costly bit of kit.. but worth it.
Mike
Mike
