Results 1 to 10 of 19
Thread: What's the largest AH battery type I can fit in my 3.2 ?
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Default What's the largest AH battery type I can fit in my 3.2 ?
    Hi guys.
    My battery failed me yesterday while carrying out a small amount of work, I think I had my radio on for about 20 minutes at the time, and the battery wasn't having it when trying to restart.
    The Comfort unit shows the battery is charging and the Voltage is around 13.5 volts when driving, but it also shows how quickly it drops to below 50% charge. Anyway, and so I am off to get it tested at Halfords later today.
    If it is past its selly by date, I would like to get an uprated replacement fitted to try to leave me a little more capacity to play with. Does anyone know if I can get a Bosch 100ah battery in the battery bay (or bigger) and if so what type number do I need to look for ?
    Regular Member blue estate's Avatar
    oh well.. I tried..
    I have an 017 type in my tray in the Vectra.. works a treat approx 90ah with a cca of around 740 depending on make of battery
    Sep 2013
    Norfolk
    Trim : SRI
    Engine : 1.9CDTI 120
    Mileage : 130000
    Mine has a Bosch battery from Amazon, 74AH, the battery is correct fitment for the 3.0CDTI. Still a lot of space in the battery tray for a bigger one.
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Quote Originally Posted by g0fvt View Post
    Thanks mate, yes I'm fairly sure that is what is in the car now, but as there is loads of space available, was wondering what the biggest one was that will still fit and clamp in
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    I got mine from ECP... Put the biggest ah available off a 3.0 cdti...
    Nice tight fit... Turns my 1.9 cdti over like a good'en...
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    I think I'll be going with a type 017 90ah ........ Unless someone got a bigger one fitted
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Most batteries for the Vectra are 175mm x 175mm end plate size.
    The length can be 295mm with the moving slider in place and 320mm with the moving slider removed, AFAIR.
    It would be interesting to find out if an even longer one would actually fit in, an 017/019 is about 353mm long, and the 017 is 190mm high.
    Ely, Cambridgeshire
    63 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I've got this fitted, can't remember the AH rating, but it's 800CCA
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Thanks Ian, I can't read the battery type from the photo, when you get the chance to take a look, I'd appreciate you letting me know and I'll do a bit more research.
    Ely, Cambridgeshire
    63 Post(s)
    Year : 2010
    Quote Originally Posted by Woody View Post
    Had a rummage through my emails and found it: http://www.battery2u.co.uk/type-110-...18-silver.aspx
    It's an 85AH but with a 800CCA rating and has gone down in price to £80 (gits lol).
  1. CDTI Battery Type/Size
    By mon in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2013, 17:53
  2. battery type
    By buffallobill in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2012, 20:00
  3. Battery pic and type
    Last Post: 1st February 2011, 22:02
  4. battery type
    By taxidriver50005 in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 20:15
  5. are 235 tyres the largest you can go?
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2009, 22:10
vectra 3.2 battery
battery for vectra c 3.2
