Took today just after the rain, what you guys think?
Great looking car mate. Where did you get the running lights from?
Had them custom made chap to fit flush and look oem, cost £40 for them, me and another taxi driver had them and was told only us 2 in the world had them at the time, now he sells them a lot!
They look really great. Will have to sort some out for mine.
Can get them if need be, they even supplied custom made relays for them as the Cree in them is that bright, and!!!!! No messing as it has a trigger wire
Decided to change my headlights for some EU ones after seeing somebody post them on here, i wanted a set the same, what you guys reckon?
Also added rear view dimming mirror (which i cleaned after fitting)
I fancy a dimming mirror in mine, but not sure about the loom side of things.
Lights look good, be good to change the indicator bulbs to silver ones to remove the orange look.
better than the taxis round here that all seem to be toyota's etc though there are a couple of vectra c hatches about
in fact an estate taxi isnt all that common either round here
Already on order from ebay mate, was worried about council tests with them but told as long as they emit the correct colour i should be fine.
As for the tinted mirror, its easy enough to make your own loom chap, for me i had live feed for power from side fuse panel, earth direct to the roof for ground, the the reverse feed from the X1 plug and door feed direct to the light cluster, so it all dims and (un?) dims when either in reverse or doors open. If you was local id do it you, even with a dodgy arm lol
