Results 1 to 5 of 5
Thread: 3.2 GSI Cam Belt
    Jun 2006
    Chester
    Default 3.2 GSI Cam Belt
    Hi,
    Could anyone please confirm when the Cam Belt is to be changed on the 3.2 GSI Vectra? I was told byt the "salesman" at Arnold Clark last year that this engine was chain driven, but that doesn't appear to be the case when I spoke to another VX garage the other day!
    Cheers
    Ian
    Sweden
    True ... Its a cam belt ... Over here its per 120000km ...
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    its a belt m8
    ignor service book change it every 40,000 allway better to be safe that sorry.
    Technical directors office
    yep, VX advise every 80,000 miles, but they had a nasty habit of snapping around 60,000.. taking both heads with them.. it's best really to change it around 40,000 miles, and do the water pump at the same time as they leak at the gland seals as the mileage increases.. the pump is only £30, and you've got the same amount of stripping to do if you want to do it later, so it makes sense to get the two done together..
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Hope mine survives until I put it in for it's service next month then. It's done 65k now and not been changed yet.
    It's going into the stealers tomorrow to check the front suspension as it feels like a wheel is trying to part company (balanced twice with no difference) - but that's a story for the Suspension section once I find out what is wrong tomorrow ...
  1. 1.9 cam belt
    By J P S in forum Engine & Drivetrain
    Last Post: 18th February 2012, 12:13
  2. Belt changes on a 1.8 VVT
    By PeterVV in forum Engine & Drivetrain
    Last Post: 27th April 2011, 21:53
  3. Fan belt / Drive belt
    By patdavis in forum Engine & Drivetrain
    Last Post: 8th January 2011, 00:39
  4. drive belt or fan belt
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2008, 10:23
  5. fan belt ??
    By arniedavo in forum Engine & Drivetrain
    Last Post: 10th September 2008, 01:16
