Results 1 to 10 of 23
Thread: Rattling Heat Shield - Rear silencer
    Regular Member gsroute's Avatar
    Feb 2013
    Scotland
    Trim : SRI
    Engine : Z18XER
    Year : 2008
    Default Rattling Heat Shield - Rear silencer
    Hi All, Any advice on how the rear heat shield is supposed to be fixed to the car, I changed the rear bumper and guess I knocked it as ever since the Heat Shield has been rattling against the bumper/exhaust most noticed when going over bumps etc. Is it really a big deal just to remove it or cut it out? The rattle seems to be more prominent at the wheel arch lining.
    Dec 2011
    Seaham
    Screw it back on or pull it off completely.
    Feb 2013
    Scotland
    Trim : SRI
    Engine : Z18XER
    Year : 2008
    Cheers, i'll prob just pull it out, unless someone thinks it should stay in? It seems to be attached at the top of the shield but where is drops between the arch and the exhaust is the problem.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    they rust through where they are bolted get some penny washers undo the bolt put washer over and fasten it back up
    heat shields are there for a reason I wouldnt remove it if I was you
    Feb 2009
    crook
    tried repairing mine.
    in the end removed it all,was sick of where ever i fixed,somewhere else would come loose
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Get some big washers info bolt got big washers an tighten bolt will be fine after that
    Feb 2013
    Scotland
    Trim : SRI
    Engine : Z18XER
    Year : 2008
    Ok, in two minds now. I'll take a better look at the weekend. I'm just not sure how its supposed to be attached to the car. Does it attach to the plastic wheel arch lining?
    Feb 2009
    crook
    are you on about wheel arch liner or heat shield ?
    Heat shield is fastened to underside of car
    Feb 2013
    Scotland
    Trim : SRI
    Engine : Z18XER
    Year : 2008
    The wheel arch lining is fine, its the metal heat shield behind it that's the problem. If it only attaches to the underside of the car then It seems to be ok then. It's the vertical section that drops down between the exhaust and plastic lining that's the problem. I've got a feeling that I'm going to trim it down to create more clearance between the lining, heat shield and exhaust.
    Feb 2009
    crook
    some places underneath i couldnt get to with drill
    Just drill fresh holes and use big washers with self tappers like @Critch says
    Make sure nothing behind where you gana drill
    Its easy to trim with tin snips if its to awkward to drill and repair
  1. heat shield
    By beat275 in forum Bodywork & Interior
    Last Post: 16th February 2013, 15:02
  2. heat shield
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th May 2012, 02:11
  3. Heat shield.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2009, 22:37
  4. Heat Shield
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2008, 22:12
vectra c loose heat shield
