Hey guys, not the most technical minded and need a bit of help with the meaning of these fault codes if some kind soul could interpret them.
I have a "Check Safeguard" warning for a while now and was wondering if one of these codes have something to do with it. I had checked internal sensors by not activating them and made no difference plus the alarm works fine and not going of randomly etc. Also if I don't lock the car and don't activate the alarm the "Check Safeguard" warning still comes up every time I put in the key and turn the ignition on. Just for reference I have a 2002 Vectra C 2.2 DTI 16v and the head unit is removed as I use my own stereo.
Here's the codes I'm getting:
U2105-71 CAN-Bus ECM Message Range/Performance (This one keeps coming back after code cleared)
B3916-0F No Communication With Alarm Siren
B3596-00 Invalid Trouble Code Please Ignore!
B1375-00 Switched System Voltage (Ignition ON) Circuit Malfunction
B3974-05 Driver Door Select Switch Window Lifter Circuit Open or High Voltage (Present)
B1325-03 System Voltage Low Voltage
U1420-04 Radio Bus Communication SDA open (Present)
U1421-04 Radio Bus Communication SCL open (Present)
U1422-04 Radio Bus Communication MRQ open (Present)
B3608-06 <Unknown DTC>
