Thread: Urgent help required please
    Aug 2012
    Tostock, Suffolk
    Default Urgent help required please
    Over the last month wile driving I've had the car with spanner light on the dash come on and I lose all power regardless if I put my foot down. When I stopped sometimes after a few mins the light goes out an I have power again sometimes I have to turn the car on and off. The car is a 2.2 dti auto signum.
    Regular Member jonnybravo's Avatar
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Tom
    it could be lots of things but you will have to have codes read to find out the fault.at a guess it's most likely the egr valve that needs cleaning but as said reading codes saves throwing money at it without knowing the problem. the code for egr is p 400
    what is the milage
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Hi Tom, yes, unfortunately you might not necessarily be able to fix a diagnosed fault yourself, but in the days of computer controlled cars, it is almost essential to have a code reader (less than £20 on ebay Amazon etc).
    Having that, and being able to read and then quote the codes and symptoms on here, will almost certainly get you some helpful, useful and knowledgeable assistance m8
    Edit - Ahh, well if you have a code reader... that's the main starting point
    Aug 2012
    Tostock, Suffolk
    Hi jonny
    Last time it happens I put a code reader on it and nothing came up. The egr I've had off and cleans a couple of months ago.
    Jul 2009
    Engine : 20 Dti
    did you check inside manifold whilst you had the egr valve off,I think if you inspect it you will find the manifold is full of carbon and gunk,if so you will have to remove manifold and clean.you will be amazed at the build up in the manifold if it's not been cleaned before,what milage have you got
    Aug 2012
    Tostock, Suffolk
    The car is now at 94500 and when I had it off I did have a look and it didn't seem to bad I've looked in the car manual and it says that if the light comes on wile driving it could be something to do with the engine or the electrics for the automatic gearbox
    Regular Member Даниил's Avatar
    May 2011
    Ashby-de-la-Zouch
    Vehicle : Vectra C
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Could be a split turbo hose. It happened on my mates dti.
    Aug 2012
    Tostock, Suffolk
    I have had a quick look but couldn't see anything. Where should I be looking ?
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Year : 2003
    Mileage : 105k
    check the boost sensor on the inlet manifold.
    Aug 2012
    Tostock, Suffolk
    Where on the inlet manifold is it located ?
  1. Urgent help required.
    By floppus in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2012, 11:50
  2. **urgent help required**
    By hogg537 in forum Engine & Drivetrain
    Last Post: 6th June 2010, 12:40
  3. urgent help required
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 18th December 2009, 18:00
  4. URGENT Help Required
    By Phil MC in forum Suspension, Wheels & Brakes
    Last Post: 4th May 2009, 13:38
  5. urgent help required
    By sulky_uk in forum General Chat
    Last Post: 22nd February 2007, 18:55
