will it fit into my car and work I did have a cd30 but that's now gone and have a aftermarket headunit
anyone know
If you have the pass code it should work iirc
would it not just plug and play with it not being connected to a Vauxhall CD player I have a pass for my car
bump also do they say things like slippy roads and refuel with a petrol pump
They do if BC is enabled but you will need the donor car pass iirc the display is paired to the HU it is only plug and play when both are installed but if you need to change settings you need the car pass unless it was divorced from the donor car.
the screen is a gid want to chamber from my bid
It would have worked in his car because the screen was paired with the original HU in that car.
he bought it seconds hand he has or had a cd30 with a bid screen
