I have had a look at the details for my 2003 BCM and CIM fitted to my 1994 Vectra-A
The options available for these 3 modules are : -
Details for my 2003 (Half CAN BCM and CIM)
BCM -
No mention of the head-unit or controls in the Variance Config tables
CIM Module table options-
Steering Wheel Control - Not Present / Scroll Wheel / Buttons
Wiper Stalk Location - Right Side / Left Side
Info Display Switch - Present / Not Present
DIS - Display Module contain these options.
EHU (Entertainment Head Unit – NCDR2011 / NCDC2013 / NCDC2015 / No Radio
Board Computer – Present / Not Present – (For GID and CID only)
Steering Wheel control – Present / Not Present
Check Control – Present / Not Present
Just thinking outside the box...
When you remove the head-unit, you cut one of the power feeds to the display.
To operate the display without the radio power feed, you need to ensure that the display is wired up as follows: -
You need Permanent Live to pins 5 and 31 - Red (one of these is controlled via the head-unit).
You need ignition live to pin 4 (Black)
You need a ground wire to pin 2 I think. (either 1 or 2).
The part that you mention about enabling anti-theft protection without a radio definately sounds familiar... I am sure it is this function that gives the warning "This is a Once Only Operation".
