Thanks Thanks:  1
Results 1 to 10 of 10
Thread: Issue with replacing broken heater control
Hybrid View
    Jun 2012
    Reading
    Default Issue with replacing broken heater control
    As you can see the main heater control on my Signum has broken off - no idea why
    The Vauxhall option is a new control unit at £120+ - so I ordered one off eBay (which is another story).
    Now I have it I find that the knob does not seem to detach from the unit (I guess it is not intended to!) so my only option is to replace the unit.
    Anyone know how to remove the existing control unit?
    ..... or a magic way to remove the one knob I need and refit it?
    Regular Member DTi Elite's Avatar
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    the unit will pop out of the dash & should have 2 wiring plugs on the back of it .
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    need to pop it out use a little flat blade screw driver under the control panel and push handle downwards do this at both ends and it should pop out
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Mileage : 53000
    Same as above have used the same method to remove 3 sets of buttons from 2. Units.
    Jun 2012
    Reading
    The other two post give suggestions for removing the whole unit - yours suggests you have managed to remove just the buttons and knobs - is that right??
    Jun 2012
    Reading
    Quote Originally Posted by cliomjh 102 View Post
    (Got the quoted bit in this time!!)
    Regular Member Chunklamb's Avatar
    Jan 2012
    Milton keynes
    Vehicle : 330D (13) Tourer 258 Auto & Signum 1.9 CDTI (07) 150 Auto
    Trim : M Sport and Design
    Engine : Z19DTH
    Mileage : 38100
    You cant remove the dials without damaging them. You need to pop out the whole unit. Slide a thin flat head screwdriver down the sides and gently expand the console... the heater panel is a snug fit and will be tough to wiggle out but once loose it will just slide out. Then simply disconnect the looms at the back and slide the new unit in its place.... but try it first, make sure it all works fine.
    Jul 2010
    This is London baby
    Trim : SXT
    Mileage : 53000
    Quote Originally Posted by Chunklamb View Post
    I beg to differ i have removed two sets off the dials/knobs on two different units. see here http://www.vectra-c.com/forum/showth...tons&highlight=
    Jul 2010
    This is London baby
    Trim : SXT
    Mileage : 53000
    Photos of the centre dial (large one) still in one bit.
  10. Thanks Vectra990 thanked for this post
  11. #10
    May 2021
    England
    Trim : SRI
    Engine : 1.9 DTH
    Quote Originally Posted by MiniVauxhall View Post
    i know this is a necro post but how in earth did you manage to remove the diels all in one bit
  1. Z20NET oil issue after replacing turbo! :@
    By signumkid in forum Petrol Engine related
    Last Post: 5th December 2011, 16:06
  2. replacing heater matrix
    By :LeeR in forum Engine & Drivetrain
    Last Post: 5th October 2011, 11:42
  3. I've broken the heater nob!
    By Awkward kid in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2011, 19:35
  4. Replacing my heater matrix on the weekend-WISH ME LUCK!
    By Vaux-Man-G in forum General Chat
    Last Post: 6th February 2010, 16:34
  5. replacing front midddle heater vents ?
    By akeem in forum Bodywork & Interior
    Last Post: 6th April 2008, 20:34
vectra c heater panel replacement
vectra c heater control knob removal
https:www.vectra-c.comforumshowthread.php166152-Issue-with-replacing-broken-heater-control
