Thread: White smoke!
    Jul 2011
    United Kingdom
    Default White smoke!
    Hi guys as the title suggests my car is smoking a bit, its a vec c estate 1.9 diesel 150 sri. i noticed it a couple of days ago there doesnt seem to be any power loss but accelerating hard in any gear produces white smoke, and earlier whilst waiting at a junction it seemed to idle badly any ideas?
    I'm sorry i know this will have been asked before but couldnt find any thing in the search.thanks.
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Quote Originally Posted by stickygreen View Post
    White smoke usually indicates water getting into a cylinder(s) - could be head gasket. Apparently its an indication you are burning anti - freeze.
    If its only smoking when you first start in the morning and clears after you have run it a while it could be valve oil seals worn and allowing a small amount of oil to drain back into the cylinder and this is burnt off when you start - although you should be able to smell the difference.
    Dec 2011
    Seaham
    Unless it is simply a build up of water in your exhaust caused by condesation etc?
    Does the white smoke clear after the engine is really hot? Or does it continue to smoke?
    Check your water level.
    Years ago, I had a brake master cylinder seal go, it was then sucking brake fluid through the cylinder, through the brake vacuum cylinder and into the engine. It burnt white!
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Or water getting into the diesel? Might be worth trying to drain the fuel filter housing to see if there's any presense of water
    Nothing to do with the fact its cold out at the moment is it? Therefore it could be perfectly normal. All my cars have done it until the exhaust has warmed up and evaporated all the condensation in it.
    A bit like breathing out in the cold, you can see your own breath for a reason
    Jul 2011
    United Kingdom
    Sorry i didnt mention it does when the engine has fully warmed up and in every gear but only when the revs have dropped, so soon after changing gear or if i let the revs drop then accelarate hard.Typical as i want to change it for a vivaro for work had my eye on one hopfully for a straight swap.
    Jul 2011
    United Kingdom
    Plus the water temp and levels are fine as is everything else except the bad idling but ive only noticed that once,i was kinda hoping it was the dpf doing its thing.
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    If its only been a one off I would keep an eye on it - as has been said could just be a case of very cold outside temp causing a lot of condensation, or as you say the dpf having its monthly cycle (they are female aren't they) causing complications. I think if it was cylinder head gasket you would have the problem all the time!
    Jul 2011
    United Kingdom
    Its getting worse the same white smoke but now idling is really bad it sounds like a bag of poo.stoped in at my mechanics on the way to work he said without looking at it possibly air flow meter or egr.wter is still normal no managment light though and incase its relavant its an 07.
    Jul 2011
    United Kingdom
    Still dont know what it was but its gone now,i fiddled around with as many electrical connections as could find under the bonnet made sure they were all tight and the next time i drove the car it was fine and still is so fingers crossed.cheers for the replies.
  1. White smoke
    By Mark fisher in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2012, 10:42
  2. Replies: 18
    Last Post: 20th November 2012, 21:41
  3. white smoke help
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 29th June 2012, 22:59
  4. white smoke help
    By smartalec0310 in forum Styling
    Last Post: 25th June 2012, 18:32
  5. White Smoke???
    By MistyMorning in forum Engine & Drivetrain
    Last Post: 4th February 2011, 17:37
