Ah spot on, I'll order them this afternoon
Hope they're gna be easy enough to fit lol
My question is... will I be required to drill or cut into any original factory fitter parts/cables?
The only hole you'll need to drill is in the headlight bulb coverplate for the wiring to go through. Something like 20 or 22mm, IIRC.
The wiring plugs straight into the existing wiring connector (with spade connectors) that normally pushes on the back of the halogen bulb.
What kit you got comin? I fitted mine last week, to a facelift.
Hi mate can you let me know where you locate the ballast I don,t really want to take bumper off in case I have to replace any faulty parts.cheers mate
Hi dave I'm thinking if ballast or bulb fails got to take bumper off again as I am not confident taking it off
