Results 1 to 7 of 7
Thread: corsa c eml help
Hybrid View
    Regular Member paul.sessions's Avatar
    May 2009
    leighton buzzard
    Default corsa c eml help
    im changing a coilpack in this car tomorrow, will the eml light go off automatically, when problem is cured. also wil my obd2 handheld scanner read and clear the codes (some cars it wont work on). also anyone know where the port is
    tia Paul
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Should clear after a drive.
    Disconnect battery for half hour.
    May 2009
    leighton buzzard
    cheers
    Regular Member Keif's Avatar
    In the Garage
    Try to clear the codes with you reader, the OBD2 port is at the bottom of the centre dash console (in front of the gearlever)
    If not, as already said, disconnect the battery (make sure you have the stereo code before hand tho)
    May 2009
    leighton buzzard
    its ok i cleared the codes with my reader after i changed tthe coilpack turned back on and was the same. so swapped the coilpacks back, mate had enough took to the local garage, and got a phonecall saying the cam shaft had snapped! the recovery guy had diagnosed as the coilpack.
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    Sounds like a 1.2 engine Corsa
    May 2009
    leighton buzzard
    correct 1.2 shocking thing is, it has only done 50k
  1. corsa vxr
    By ecotommy in forum The 'Off Topic' room
    Last Post: 22nd February 2011, 19:26
  2. Anyone know anything about Corsa 1.2`s?
    By PeterVV in forum General Chat
    Last Post: 30th January 2009, 21:53
  3. Corsa C Alloy And Corsa D Grille
    By andy.l in forum Parts for sale
    Last Post: 6th May 2007, 12:46
  4. Corsa VXR
    By Madgunner in forum General Chat
    Last Post: 16th March 2007, 00:56
