Just bought an 03 elegance and have noticed that the rear passenger door handle is a bit loose, and does not return fully after being pulled.
Is it a new handle required or can the mechanism be tightened / adjusted?
When you open the door, look above the lock mechanism, there is a grommet covering a torx screw. Take it off, pull the handle to the open position and undo the screw fully. It won't come out, but I believe it needs to be undone. That's the first thing I'd check.
Ok thanks for that will have a look and see
Tried that this morning but when I loosened the nut completely, the handle would not go back in at all lol
See if the pictures in the following how2 help you
http://www.vectra-c.com/forum/showthread.php?t=57410
http://www.vectra-c.com/forum/showthread.php?t=15157
Thanks for that.
Is it likely taking the handle out and then putting it back in will tighten it up ?
