Thread: cdr2005 failing
    May 2006
    North yorkshire
    Default cdr2005 failing
    sorry if this has been answered before but i'd just likr to check the following as my cdr2005 has started to make some horid noises when switched on so will need replacing.
    1 when i change the headunit will i be able to use the six buttons on the steering wheel.
    2 will all the trip computer functions still work
    3 will i be able to change the date and time on the display
    4 am i correct in thinking that sony,pioneer and alpine still make good quality headunits(its been 10years since i been interested in changing a headunit)
    if it helps i drive an 04 sri cdti 150
    Regular Member Harry's Avatar
    Uxbridge, London
    tarandy, here's some answers to your questions:
    1) the six button can be used but you need to buy the correct wiring for the specific make of headunit you purchase. i have recently upgraded to an aftermarket unit and even though i've got the wiring i can't get the buttons to work...nobody else has had this problem so i think i got a dodgy wiring loom
    2) trip computer functions will work but you will lose the radio display that is usually shown on the screen i.e. the station frequency or CD - this depends on what screen you have to begin with and how much info is shown. I had the CDR2005 aswell so i assume you have the yellow screen with black text.
    3) i've been wondering the same thing, i think the time can only be changed through the standard headunit. so you'll need to plug it back in every six months
    4) yep....all the companies you mentioned are reputable and make very good units indeed.
    Jan 2006
    Skynet HQ EMEC#5
    my display is the basic one with the the two buttons for setting the time. When I upgraded the cdr2005 to a Sony mp3 unit, I got the connects2 display & steering control adapter that shows ID3 mp3 track info on the display. It also displays radio station name.
    Feb 2006
    Guttedsville
    I've got an Alpine 9850 I pod compatible stereo in mine and still have the use of my steering wheel buttons. Don't ask how, as I got fitting for £20 when I bought it!!
    Sound quality is superb, too loud sometimes!
    May 2006
    North yorkshire
    thanks for that.
    Yes its the orange screen with the black text.
    So all i have to do now is choose a headunit and go from there.
    thanks again.
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    I would avoid Sony personally but the rest are ok!
    Jan 2006
    Skynet HQ EMEC#5
    Nothing wrong with Sony, but that's your own opinion
  1. possible alternater failing?
    By Dane-10 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2012, 18:32
  2. Battery Failing Maybe
    By WeDesign in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2012, 17:03
  3. Possible Oil Pump failing???
    By dtmwelburn in forum Engine & Drivetrain
    Last Post: 11th September 2011, 19:52
  4. Wipers failing.
    By izonoky in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2009, 23:08
  5. Failing Handbrakes ...(Recalls)
    By The-Bandit in forum General Chat
    Last Post: 3rd February 2008, 22:13
