Results 1 to 10 of 25
Thread: What engine temperature should the 150CDTI Be?
    Regular Member 150_SRI's Avatar
    Sep 2010
    Lincs
    Default What engine temperature should the 150CDTI Be?
    Hi All,
    I have a 2006 SRI 150 6spd CDTI Vectra. It takes a long time to warm up and when i am driving it, on the temp gauge near the speedo it operates at about 80 - 83 c.
    Ive driven other cars that sit on 90c all the time, but this car doesnt really get there, only gets up to about 87c when sat in traffic for a long time, but when i start driving again goes back down to about 80c, is this right?
    Im concerned as im sure this could affect fuel consumption?
    If anyone has one of these, how long would you say it should take to warm up from cold when started and driving straight away? Miles or time wise?
    Cheers,
    Regular Member OPC's Avatar
    Mar 2009
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Year : 2008
    What you say sounds about right, my 08' 150 SRi CDTi only goes upto 90 degrees in heavy traffic or when driven very hard, but then very quickly returns to 83-85 degrees. Takes around 5 miles to warm up on gauge, but warm air passes thru vents a little quicker.....will take a while longer when deep winter sets in.
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    That is normal for cdti. Unless you get it less than 80(internal warming is not on), the temperature you said is normal to me. It make takes few miles (3-5?) to warm up, especially first drive in the cold morning.
    Regular Member Si-SRI's Avatar
    Oct 2009
    LINCOLNSHIRE
    Exactly as above...mine takes longer to warm up..but heat through the vents before the gauge moves...
    Normally 83-85 around town and on a run...upto 90 in stop-start conditions but comes down to 85 very quickly when moving again.
    Sep 2010
    Lincs
    Ok cheers guys. As you all have, hot air does come through depite showing cold on the gauge and then operates just over 80c. Just wanted to check as my old petrol 150 used to operate nearer to 90 all the time.
    thanks for the input.
    Wales, UK
    Same here too. Disels naturally take a little longer to warm I think.
    Sep 2010
    Lincs
    slightly off topic, can anyone tell me how to upload a picture of my car into my avatar?
    Regular Member paul_sri150's Avatar
    Liverpool
    sounds about right
    mine sits between 80-90
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    As said settles at about 85 - like my previous 1.8 and 2.0T both did.
    Jul 2008
    VXR where are you now
    16 Post(s)
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    how much is a thermostat for a cdti (150) from the stealers
  1. Engine temperature up and down
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 7th March 2013, 21:01
  2. Engine Temperature keeps going up and down (2.0 DTi)
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2013, 00:29
  3. 2.2 DTI engine temperature
    By Alistair123 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2011, 00:21
  4. Engine temperature
    By NI-2.2SRI in forum Engine & Drivetrain
    Last Post: 2nd February 2009, 11:40
  5. Engine temperature
    By 2ltrT in forum Engine & Drivetrain
    Last Post: 25th July 2005, 16:10
vectra c 2.0t engine temperature
