I've checked my centre console and see I have the plug connectors for heated rear seats. I'm not really interested in adding that feature but was wondering about using the feed. What I'm looking at is fitting some entertainment in the back for the kids. My plan is to fit an archos mp4 and A/V dock into the rear console to replace the ashtray then hardwire a set of composite vid & audio L & R sockets both sides, put headrest screens in with cables through the front seat backs, out the bottom of the seat and into the sockets in the console to supply the vid/audio from the player. But as well as that side of things, I'm also going to need a power supply.
My question is (as I don't have a meter), are the heated rear seat plugs live as they are? I'm hoping they may be powered anyway as they're taped up and covered and I have heated fronts already. If they don't have power is it just a case of fitting a relay or fuses in the right place or would I have to get the rear heated seat feature enabled with tech2?
Also there are 5 wires in each plug as follows:
Green plug
1. black & white
2. brown
3. no wire
4. grey & yellow
5. brown & white
6. brown
Brown plug
1. black& white
2. brown
3. no wire
4. grey & yellow
5. brown & green
6. brown
Can anyone shed light on what wire is for what? Now I know I could take a feed from the rear 12v outlet but I have other plans for that so would prefer not to use it on this project and as I have the plugs for rear seat heaters there already it seems a shame not to use them. Any advice or info would be much appreciated.
