The WE50 5.5kg high spin washer is a very reliable, robust and simple to operate washer ideal for all applications. Incorporates type &a& airgap compliant with WRAS regulations. Can be undercounter, free standing or stacked.
Features and benefits:
* DSS programs to HSG(95) 18 or standard programs
* stacking or under worktop
* pump or gravity drain
* single or three phase
* manual or coin operation
* unique suspension system
* Latest type ‘A’ Airgap
* No more requirement for a dedicated supply
* Machine can be connected directly to mains water supply
technical specifications
Drum volume in litres: 53
Drum capacity in kgs/lbs: 5.5/12
Extraction rpm / G-factor: 1000
Dimensions (WxDxH):
595 x 595 x 850
Net weight: 73
Please note this has a big diameter drainage on the back.
only selling as this was in the house when i moved in so i bought it and now i am moving the new landlord wont let me drill a 8 inch drain hole in the wall LOL.
collection is only
and i am wanting
£200 and open to offers.
this washer is brilliant and i mean its the best thing i have ever had.
PLEASE ALSO NOTE
the description says what it can do as well coin op etc..etc.. this washer only has the standard fitments witch means it plugs into a standard plug and normal operates normally no coins etc..
here is link to the wash spec sheet.
http://www.opl-ltd.co.uk/technical/WE50.pdf
