Just get a dummy one. Remove the aerial base from your vectra. You will need to peel back the roof lining a bit to access the nut which secures it. Then disconnect the blue plug which should be above your drivers side, rear window. This will allow you to totally free your aerial base. Once freed, reconnect it but this time with the aerial base on the underside of your roof (between roof and roof lining) the long arial can stay connected. Just tape it to the underside of the roof as the roof lining leaves a bit of a cavity between itself and the roof. Be sure to seal your fin properly as water will leak in and through your hole, making any passengers in the rear centre seat, a little bit erm... wet
