Hi,
This is my first post and may be going over old ground, but any help or links are appreciated. I've got a 2003 Signum 2.2DTi which I guess has the Y22DTR engine which has done 70k. Everything runs fine 99% of the time...however a few months ago I started to get a power loss and stall when I was trying to gently apply throttle while cruising in 5th at around 1200rpm. Engine would restart fine and there was no spanner error. This seems to have mutated into a diiferent kind of stall; after a couple of hours motorway cruising, the engine will lose power/stall and restart itself in 2 second pulses. Not great at 70mph. When it's in this mode it will also stall at junctions, unless the revs are kept up. It will then recover and be fine. Always starts fine from cold and runs smooth. Fuel consumption is godd at 50mpg. Again, no spanner error on the dash. I've read the pending error codes and have got at various times P0638, P0400 and the MAF error. Tried replacing the MAF with an aftermarket one and that made the car very jerky between 1 - 2,000 rom, so the original MAF is back in. I've checked the vacuum pipes I can get to and they seem fine. What I think is the EGR on the front of the engine seems to move OK in-situ, but hasn't been taken out yet. The fault is annoying but not yet permanent to make it an easy fix at main dealer. Cheers
