Thread: P242F Error Codes
    Redditch
    Default P242F Error Codes
    Last night my car went into limp mode, after reading the ECU I had the good old EGR Error code, a P2279 and P242F (75). The garage has replaced my EGR as the warranty company paid for this then not long after on the drive home the temperature went up to 90 and the spanner light came on, previously only the Engine Light came on. So on getting home I read the ECU to find 2 error codes, P242F (75) and P242F (58).
    Has anyone any ideas what else this could be as its booked back in at the garage on Tuesday, normal temp for the car is around 80 - 85 not normal for it to go up to 90 and its the CDTi 150.
    Any help much appreciated.
    Edinburgh
    P2279 Intake Air System Leak Detected B-035
    Thread about P2279:
    http://www.vectra-c.com/forum/showthread.php?t=73617
    Probably related to your EGR tbh.
    P242F Particulate Filter Pressure Sensor Range/Performance B-031
    Redditch
    Hi Big Knox, thanks for that, I had read that one but it says that the EGR fixed it, I have just replaced it with a brand new one and got the error Couldn't find any leaks but will have to see what the garage find
    Redditch
    The DPF started to regenerate so let it finish and gave the car a good blast, problems have gone away for now. Just need to get the fiat gaskets and hopefully fix the issue once and for all
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Mine threw up the P2279 when the DPF became blocked.
  1. error codes
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2012, 20:33
  2. error codes
    By bellstephen in forum Vectra C / Signum Troubleshooting
    Last Post: 21st February 2012, 17:16
  3. Error codes
    By Ziggy in forum Engine & Drivetrain
    Last Post: 17th February 2012, 14:26
  4. error codes
    By bower in forum Engine & Drivetrain
    Last Post: 7th November 2010, 23:01
  5. Hello All..... I'm after your help (ERROR CODES)!!!
    By albertoleach in forum Introduce yourself.
    Last Post: 9th March 2009, 09:50
p242f-75
https:www.vectra-c.comforumshowthread.php111045-P242F-Error-Codes
P242F VAUXHALL
p242f zafira
vectra p242f
p242f75
p242f-75 vectra c
Saab DTC P242F-75
VAUXHALL P242F
2279 error car codes
p242f fault code vauxhall
p242f 2016 vauxhall
p242f opel
error code p242f_75Opel P242F hibakódvauxhall code p242fp242f particulate filter pressure sensor range performance242f error code opelVAUXHALL P242F vectra autoVauxhall P242F-Oopel veczra c P242ffault p242f opel2008 vectra fault code p242fOPEL P242Fvauxhall zafira p242f code
