Thanks Thanks:  1
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Rear Suspension Diagram
    Regular Member daviem-rfc's Avatar
    SUNNY DUMBARTON
    Default Rear Suspension Diagram
    Vec C - Anyone got a diagram of what the rear suspension components look like and how it is set up?
    Regular Member Jezzy's Avatar
    S.E
    Any bit in particular?
    SUNNY DUMBARTON
    Nope, just the full set up with parts named if possible. Trying to get an idea for how all the parts connect and look as im planning in getting a bit more involved in the maintenance of my car
    S.E
    Key:
    1) Rear axle body
    2) Additional link, upper
    3) Damping rubber for rear spring, top
    4) Rear spring
    5) Bump stop and damping rubber, lower
    6) Transverse link, lower (aluminium)
    7) Stub axle with wheel bearing unit, brake disc, brake caliper
    8) Trailing link with damping bushing and trailing link bracket on vehicle underbody
    9) Shock absorber
    10) Additional link, lower
    11) Bracket for stabiliser mounting
    12) Stabiliser (aka anti-roll bar)
  5. Thanks andy vectra thanked for this post
  6. #5
    SUNNY DUMBARTON
    Key:
    1) Rear axle body
    4) Rear spring
    9) Shock absorber
    Thanks for that mate, just what I was looking for
  7. #6
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Trim : Elite with sports pack
    Engine : CDTi 150
    Mileage : 103000
    i found this one
  8. #7
    Can someone please advise at the labour time to replace each item 9; nearside shock absorber, offside shock absorber
    Also part numbers for a 2005 3.0 V6 CDTi with standard SRi suspension
  9. #8
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    an hour labour tops mate. i done my own a couple weeks ago, both sides in 30mins two bolts top one and bottom one on each side
  10. #9
    Quote Originally Posted by Keithy View Post
    I am after the actual VX labour rates, probably from TIS
    What can take the "average joe" 0.5 hours is typically charged for a minimum 1.0 hours by VX
    I need to get my nearside rear replaced, as it has clearly failed, so both rears will be replaced
    Getting some quotes tomorrow
    Sadly can't claim on the AA Brekadown warranty, unless I can come with some kind of excuse, policy wording "An AA patrol must attend to the breakdown"
    Perhaps park after work on Tuesday, then phone them up "There is a large amount of oil at the back of the car, I need it examined before I proceed with my journey"
  11. #10
    Two quotes from dealerships, £290 and £295, in effect £150 per side, obviously both sides would be replaced
    I make that about £70 and 1.5 hours labour per side
  1. Hows my wiring diagram for fron & rear PDC?
    By muffking in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2012, 19:34
  2. rear parking sensors position diagram.
    By azacbr6 in forum Styling
    Last Post: 13th August 2011, 22:32
  3. Rear suspension diagram
    By Jonsey in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2011, 21:49
  4. Vectra C Z18XE rear suspension diagram
    By mrbiggest in forum Suspension, Wheels & Brakes
    Last Post: 11th October 2010, 11:40
  5. Rear Suspension
    By cdtisri in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2007, 21:42
https:www.vectra-c.comforumshowthread.php104892-Rear-Suspension-Diagram
vauxhall vectra c rear suspension diagram
drawings of vectra c rear bushes07 vectra back suspensionvectra c rear suspension diagram site:www.vectra-c.comvectra c 1.9 cdti sri rear suspension diagramvectra:c rear suspension diagramvectra c rear suspension exploded vectra c rear hub assembly diagramvectra c rear hub diagramvectra cdti 150 rear suspension stabilizerrear suspension diagramdiagram of rear suspension on 07 vectra srivectra c front suspension diagramvectra c rear axlevauxhal vectra c rear suspension diagramVectra c rear component diagram
