31st January 2010, 00:28
#1
Z20NET Spec Sheet
Because I can do a good impression of a geek, and because I like my engine, I've drawn up what I hope will become a sticky once it's finished, and act as a reference guide to the Z20NET for forum members.
At the moment it consists of a picture of the engine, some facts and figures, and BHP and torque curves.
Please feel free to point out any inaccuracies, and make suggestions for additional information that should be included, and if you also have that information to hand, so much the better.
Engine designation:
Vauxhall:
Z20NET (Z = Euro4 emissions standard, 20 = 2.0 litre, N = compression ratio 9.0-9.5:1, E = injection, T = turbocharged)
Saab:
B207L
Engine installation
Front, transverse in front of axle, 10° backward inclined
Cooling system
Liquid, sealed circuit
Cylinders, number
4
No 1 cylinder location
At timing chain end
Bore (mm)
86
Stroke (mm)
86
Displacement (cc)
1998
Compression ratio
9.5 : 1
Engine, type
In line; 5 main bearings
Cylinder block/ head material
Aluminium/ aluminium
Camshaft(s), location
2 overhead (DOHC), driven by chain
Valve train
Roller rocker with hydraulic bucket tappets
Valve, arrangement
v; 4 per cylinder
Valve, adjustment
Automatic – hydraulic
Fuel system
Sequential multi point fuel injection
Ignition system
Electronic ignition map, ignition coil direct to spark plug
Fuel pump
Electric, in tank
Emission control system
3 - way cat. conv. with 2 oxygen sensors
Output
129 kW / 175 BHP at 5500 RPM
Specific power (kW/l; hp/l)
64.6; 87.6
Max. torque (Nm at 1/min)
265 kW / 195 lb ft at 2500 RPM
Specific torque (Nm/litre)
132.6
Mean effective pressure at max. power/ max. torque (Nm/litre)
1408.7/ 1667.5
Average piston speed (m/s)
15.8
Number of camshaft bearings
6 per camshaft
Lubrication:
Engine oil, capacity (l)
6
Difference between Min and Max markings on dipstick
1 litre
Oil filter type
Disposable paper cartridge, top mounted
Oil filter nut size
32mm
Oil filter nut torque setting
25 Nm / 18 lb ft
Sump drain plug torque setting
25 Nm / 18 lb ft
Minimum oil pressure at 80 C:
Crankcase
2.0 bar at 1000 RPM
Cylinder head
0.8 bar at 1000 RPM
Oil pressure warning switch activates at
0.3 bar
Oil cooler thermostat opens at
107 C (No thermostat fitted from 2008 onwards - oil cooling at all temperatures)
Coolant capacity (l)
7.5
Battery 12V, capacity (Ah)
66
Alternator 14.2V, capacity (W)
1704
Max. service interval
20,000 miles or 2 years
Emission compliance
Euro 4
OEM spark plug brand/type
NGK PFR6T-10G
Electrode gap
0.9mm to 1.0mm
Spark plug torque setting
28 Nm / 21 lb ft
Firing order
1-3-4-2.
Post Thanks / Like - 3 Thanks, 3 Likes
1st February 2010, 23:39
#2
First revision is complete, I've added part numbers for some commonly replaced parts specific to this engine, some more diagrams of the engine and labelled some of the major components. As before, suggestions/revisions welcome.
Engine designation:
Vauxhall:
Saab:
B207L
Engine installation
Cooling system
Cylinders, number
4
At timing chain end
Bore (mm)
86
Stroke (mm)
86
Displacement (cc)
1998
Compression ratio
9.5 : 1
Engine, type
Valve train
Valve, arrangement
v; 4 per cylinder
Valve, adjustment
Turbocharger
Garrett GT 2052S
Fuel system
Ignition system
Fuel pump
Electric, in tank
Output
64.6; 87.6
132.6
1408.7/ 1667.5
15.8
6 per camshaft
Lubrication:
6
1 litre
Oil filter type
Oil filter nut size
32mm
25 Nm / 18 lb ft
25 Nm / 18 lb ft
Crankcase
2.0 bar at 1000 RPM
Cylinder head
0.8 bar at 1000 RPM
0.3 bar
Oil cooler thermostat begins to open at
107 C, fully open at 120 C (No thermostat fitted from 2008 onwards - oil cooling at all temperatures)
7.5
66
1704
Emission compliance
Euro 4
NGK PFR6T-10G
Electrode gap
0.9mm to 1.0mm
28 Nm / 21 lb ft
Firing order
1-3-4-2.
Commonly replaced parts
Charged air bypass valve, Vauxhall part number 55354158
Oil filter element, 93175493
O-ring seal for oil filter, 90537437
Mass air flow sensor, 24452491
Thermostat and flange, 90537811
Engine from the front:
Engine from the rear:
Component location:
Key:
1 Air box
2 Brake fluid reservoir
3 Coolant reservoir
4 Mass air flow sensor
5 Spark plugs and ignition coils cover
6 Turbocharger heat shield
7 Oil cooler
8 Air conditioning low pressure pipe valve
9 Coolant return pipe ventilation valve
10 Fuel rail de-pressurising valve
11 Alternator
12 Charged air boost control valve
Post Thanks / Like - 2 Thanks, 4 Likes
2nd February 2010, 01:15
#3
Maybe a sticky for veccy/siggy engines, then inside that post links to each engines own "non-stickied" thread?
10th February 2010, 13:41
#4
sticky created
10th February 2010, 15:11
#5
Post Thanks / Like - 1 Thanks, 0 Likes
hoose thanked for this post
1st January 2011, 11:34
#6
Post Thanks / Like - 1 Thanks, 2 Likes
horaa thanked for this post
1st January 2011, 17:40
#7
Post Thanks / Like - 1 Thanks, 1 Likes
1st January 2011, 22:55
#8
whats the part that bolts on the side of the cam cover at the side round shape thing ??
1st January 2011, 23:04
#9
1st January 2011, 23:13
#10
yes mate that's it, should it make a tapping rattle clicking sound??
