Thanks Thanks:  9
Likes Likes:  10
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 66
Thread: Z20NET Spec Sheet
    Regular Member Jezzy's Avatar
    May 2009
    S.E
    Default Z20NET Spec Sheet
    Because I can do a good impression of a geek, and because I like my engine, I've drawn up what I hope will become a sticky once it's finished, and act as a reference guide to the Z20NET for forum members.
    At the moment it consists of a picture of the engine, some facts and figures, and BHP and torque curves.
    Please feel free to point out any inaccuracies, and make suggestions for additional information that should be included, and if you also have that information to hand, so much the better.
    Engine designation:
    Vauxhall:
    Z20NET (Z = Euro4 emissions standard, 20 = 2.0 litre, N = compression ratio 9.0-9.5:1, E = injection, T = turbocharged)
    Saab:
    B207L
    Engine installation
    Front, transverse in front of axle, 10° backward inclined
    Cooling system
    Liquid, sealed circuit
    Cylinders, number
    4
    No 1 cylinder location
    At timing chain end
    Bore (mm)
    86
    Stroke (mm)
    86
    Displacement (cc)
    1998
    Compression ratio
    9.5 : 1
    Engine, type
    In line; 5 main bearings
    Cylinder block/ head material
    Aluminium/ aluminium
    Camshaft(s), location
    2 overhead (DOHC), driven by chain
    Valve train
    Roller rocker with hydraulic bucket tappets
    Valve, arrangement
    v; 4 per cylinder
    Valve, adjustment
    Automatic – hydraulic
    Fuel system
    Sequential multi point fuel injection
    Ignition system
    Electronic ignition map, ignition coil direct to spark plug
    Fuel pump
    Electric, in tank
    Emission control system
    3 - way cat. conv. with 2 oxygen sensors
    Output
    129 kW / 175 BHP at 5500 RPM
    Specific power (kW/l; hp/l)
    64.6; 87.6
    Max. torque (Nm at 1/min)
    265 kW / 195 lb ft at 2500 RPM
    Specific torque (Nm/litre)
    132.6
    Mean effective pressure at max. power/ max. torque (Nm/litre)
    1408.7/ 1667.5
    Average piston speed (m/s)
    15.8
    Number of camshaft bearings
    6 per camshaft
    Lubrication:
    Engine oil, capacity (l)
    6
    Difference between Min and Max markings on dipstick
    1 litre
    Oil filter type
    Disposable paper cartridge, top mounted
    Oil filter nut size
    32mm
    Oil filter nut torque setting
    25 Nm / 18 lb ft
    Sump drain plug torque setting
    25 Nm / 18 lb ft
    Minimum oil pressure at 80 C:
    Crankcase
    2.0 bar at 1000 RPM
    Cylinder head
    0.8 bar at 1000 RPM
    Oil pressure warning switch activates at
    0.3 bar
    Oil cooler thermostat opens at
    107 C (No thermostat fitted from 2008 onwards - oil cooling at all temperatures)
    Coolant capacity (l)
    7.5
    Battery 12V, capacity (Ah)
    66
    Alternator 14.2V, capacity (W)
    1704
    Max. service interval
    20,000 miles or 2 years
    Emission compliance
    Euro 4
    OEM spark plug brand/type
    NGK PFR6T-10G
    Electrode gap
    0.9mm to 1.0mm
    Spark plug torque setting
    28 Nm / 21 lb ft
    Firing order
    1-3-4-2.
  2. Thanks Mooo, JUANNORTON1992, horaa thanked for this post
    Likes StephenC99, JUANNORTON1992, horaa liked this post
  3. #2
    May 2009
    S.E
    First revision is complete, I've added part numbers for some commonly replaced parts specific to this engine, some more diagrams of the engine and labelled some of the major components. As before, suggestions/revisions welcome.
    Engine designation:
    Vauxhall:
    Saab:
    B207L
    Engine installation
    Cooling system
    Cylinders, number
    4
    At timing chain end
    Bore (mm)
    86
    Stroke (mm)
    86
    Displacement (cc)
    1998
    Compression ratio
    9.5 : 1
    Engine, type
    Valve train
    Valve, arrangement
    v; 4 per cylinder
    Valve, adjustment
    Turbocharger
    Garrett GT 2052S
    Fuel system
    Ignition system
    Fuel pump
    Electric, in tank
    Output
    64.6; 87.6
    132.6
    1408.7/ 1667.5
    15.8
    6 per camshaft
    Lubrication:
    6
    1 litre
    Oil filter type
    Oil filter nut size
    32mm
    25 Nm / 18 lb ft
    25 Nm / 18 lb ft
    Crankcase
    2.0 bar at 1000 RPM
    Cylinder head
    0.8 bar at 1000 RPM
    0.3 bar
    Oil cooler thermostat begins to open at
    107 C, fully open at 120 C (No thermostat fitted from 2008 onwards - oil cooling at all temperatures)
    7.5
    66
    1704
    Emission compliance
    Euro 4
    NGK PFR6T-10G
    Electrode gap
    0.9mm to 1.0mm
    28 Nm / 21 lb ft
    Firing order
    1-3-4-2.
    Commonly replaced parts
    Charged air bypass valve, Vauxhall part number 55354158
    Oil filter element, 93175493
    O-ring seal for oil filter, 90537437
    Mass air flow sensor, 24452491
    Thermostat and flange, 90537811
    Engine from the front:
    Engine from the rear:
    Component location:
    Key:
    1 Air box
    2 Brake fluid reservoir
    3 Coolant reservoir
    4 Mass air flow sensor
    5 Spark plugs and ignition coils cover
    6 Turbocharger heat shield
    7 Oil cooler
    8 Air conditioning low pressure pipe valve
    9 Coolant return pipe ventilation valve
    10 Fuel rail de-pressurising valve
    11 Alternator
    12 Charged air boost control valve
  4. Thanks Lao, horaa thanked for this post
    Likes Lao, hoose, Entharion, horaa liked this post
  5. #3
    Regular Member sy_uk's Avatar
    Newcastle
    Maybe a sticky for veccy/siggy engines, then inside that post links to each engines own "non-stickied" thread?
  6. #4
    Jan 2009
    WGAF#5
    sticky created
  7. #5
    Jan 2009
    WGAF#5
    Jezzy,
    additional component for Tubo solenoid
    looks identical to the charged bypass valve that so many of us have fitted and works in tandem with it - do not confuse them as they do have different reference values and will not effectively work if reversed
    Vauxhall part no 12787706 description "valve"
    location as per your picture of the engine with the cover removed ..
    located above the dipstick with 3 pipes and electrical connector coming out of the unit .
    my advice is if your fitting "Charged air bypass valve, Vauxhall part number 55354158" you fit this one as well - belt and braces but for around a tenner might save you an additional trip to the dealers
    regards
    Dez
  8. Thanks hoose thanked for this post
  9. #6
    May 2009
    S.E
    Pictures of the rarely seen turbo side of the Z20NET:
  10. Thanks horaa thanked for this post
    Likes hoose, horaa liked this post
  11. #7
    May 2009
    S.E
    Air/fuel flow diagram (not to scale), from Saab:
    KEY
    1. Check valve, crankcase ventilation
    2. Air filter
    3. Mass air flow sensor (MAF)
    4. Turbo
    5. Charge air cooler
    6. By-pass valve
    7. Solenoid valve, turbo by-pass
    8. Throttle body actuator
    9. Intake air temperature sensor
    10. Manifold absolute pressure sensor
    11. Engine
    12. Crankcase ventilation, oil trap
    13. Check valves
    14. EVAP canister purge valve
    15. Evaporative emission canister
    16. Wastegate valve
    17. Charge air regulator
    18. Boost pressure control valve
    19. Oxygen sensor
    20. Catalytic convertor
    21. Exhaust temperature sensor
    22. Front silencer
    23. Rear silencer
    24. Vacuum pump
    25. Brake servo
    26. Check valve
    27. Fuel pressure regulator
    28. Atmospheric pressure sensor
  12. Thanks horaa thanked for this post
    Likes horaa liked this post
  13. #8
    Aug 2010
    herts
    whats the part that bolts on the side of the cam cover at the side round shape thing ??
  14. #9
    May 2009
    S.E
    This one?
    That's the vacuum pump.
  15. #10
    Aug 2010
    herts
    yes mate that's it, should it make a tapping rattle clicking sound??
  1. exclusive spec vs club spec
    By rjw in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2012, 20:10
  2. what does this mean on my service sheet?
    By Ginge7289 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 09:52
  3. Z22YH - 2.2 16v Ecotec Direct Spec Sheet
    By tomtaylor15 in forum Petrol Engine related
    Last Post: 27th June 2010, 16:29
  4. sevice sheet
    By dominic32 in forum General Chat
    Last Post: 18th July 2009, 18:02
  5. Holey sheet lol
    By Dose in forum Comedy & Humour
    Last Post: 2nd May 2009, 17:22
https:www.vectra-c.comforumshowthread.php101304-Z20NET-Spec-Sheet
z20net
z20net engine
vectra-cz20net vacuum diagramhttps:www.vectra-c.comforumshowthread.php101304-Z20NET-Spec-Sheetpage6ENGINE Z20NETZ20NET Ez20net spark plug gapvectra z20net z20net catmotor z20netengine 2 0 tdci opel insignia shemevauxhall insignia 2.0 turbo diesel engine diagramvectra 2008 engine diagramwhats the z20net enginez20net engine specsz20net time injectionz20net gt 20 max doladowaniez20net brake vacuum hosevectra c z20net specopel vectra c 2003 atmosphere thermometervectra 2.0 engine on blocksz20net garrett turbocharger connection diagramz20net engine diagram
