Originally Posted by
lesj
This any help
Field Remedy: 1849
Subject: Engine Z19DT/H - Jerking
Models: Engines: Option:
Vectra-C 2004...2005,Signum 2004...2005 Z19DT| Z19DTH,Z19DT| Z19DTH
Complaint: Customer complains about a kind of jerking at steady state or at slight acceleration.
Cause: The problem is caused by high EGR-rate in combination with component tolerances.
Production:
Remedy:
In case of customer complaint reprogram the ECU with new software as of TIS 2000-CD, Version 67.
If the problem occurs with the new software again, contact ETAC for further information.
Please note:
A replacement of any parts (injectors, high-pressure pump, EGR valve, ECU, etc.)is not necessary.
FunctionalGroup: J - Engine
Complaint Group: 18 - Poor Drivebility
Trouble Code: None
