Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Flat Spot/Stutter or hesitation on 2006 1.8 VVTi SRI
    Regular Member Fireyfella's Avatar
    Jun 2007
    York
    Vehicle : Vectra SRi NAV XP2
    Engine : 1.9 CDTi
    Mileage : Plenty
    Question Flat Spot/Stutter or hesitation on 2006 1.8 VVTi SRI
    Hi Guys
    Does anyone have an idea why when I set of in 1st and get up to about 5-10mph my car seems to stutter or hesitate for a second or two whilst you continue to accelerate? It then jumps to the speed you would have been at if you had kept accelerating making me look like a twXt I mean a ‘new driver’.
    Could it be the MAF? I believe this is the ‘Air Flow Sensor’? or would it have anything to do with the plugs?
    Your advice would be appreciated, Regards Andy
    P.S, I have only had the car a couple of weeks, it has full service history and I have just had the cam belt done, but it did the same before the belt and it has been to the moon and back with regards to the milage.
    May 2007
    south ockendon
    try doing the airbox mod, normally sorts it out or at least improves it
    its not afault as such, more like a characteristic,lol
    my 1.8 used to do the same but was better once the mod was done, and you get used to it
    Jun 2007
    York
    Engine : 1.9 CDTi
    Mileage : Plenty
    Quote Originally Posted by pyro_maniac View Post
    What Mod, is it changing the MAF
    Jun 2007
    York
    Engine : 1.9 CDTi
    Mileage : Plenty
    Quote Originally Posted by Fireyfella View Post
    Just noticed your ID, Should I be talking to you
    May 2007
    south ockendon
    lol, sure you can talk to me
    the mod is not changing the MAF or anything else, just removing a part of the intake trumpet inside the airbox
    http://www.vectra-c.com/forum/showthread.php?t=77893
    Jun 2007
    York
    Engine : 1.9 CDTi
    Mileage : Plenty
    Looks simple enough, thanks for the thread. I will give it a go after I order a new filter, might as well change it whilst it’s off. Should I go for a K & N, Piper Cross, Fram or any other ideas?
    Jul 2009
    lanark
    hi mate, i work for a stealer up in scotland,
    your engine is a z18xer, which reqires an sps which un technically speaking is an ecu upgrade to get shot of this problem.
    my old man has one and thats what vauxhall technical told me,
    carried out this to my dads 3 month agoo, and he has had a big grin on his face since. hes always at me about it.
    1 more power
    2 no flat spot
    3 starts alot nicer in the morning
    4 smoother in traffic
    5 5 extra mpg
    no bad mate eh
    May 2007
    south ockendon
    just change it for a standard filter, i had a K&N on mine and noticed hardly any difference over a standard one, just a little bit more noise
    Jun 2007
    York
    Engine : 1.9 CDTi
    Mileage : Plenty
    Quote Originally Posted by vxr-jim View Post
    1 more power
    2 no flat spot
    5 5 extra mpg
    no bad mate eh
    Tell me more, How, What, Where & most all COST?
    Jul 2009
    lanark
    technically speaking,
    all you do is plug your car in to the laptop, read your ecu settings,
    they get shipped straight to germany, some little german fella loads 2009 software onto the phoneline,
    it goes into your cars ecu via the laptop.
    5 mins it takes, should be a part of your annual service if the dealer is their job right...................
    some dealers are ........ are........ are................. you know what i mean.
    but trust me mate, this is the answer to all your questions
    my dads goes like a scalded cat, iv done it to my 2006 astra vxr and mate..... what a difference
  1. think i may have finally cured the famous flat spot hesitation,read on....
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 20th April 2014, 21:19
  2. Another Z19DTH flat spot/hesitation thread
    By Teapot in forum Engine & Drivetrain
    Last Post: 29th December 2012, 23:47
  3. Replies: 0
    Last Post: 8th August 2011, 16:39
  4. flat spot/hesitation
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2008, 16:53
  5. flat spot???
    By bobbyboy in forum Engine & Drivetrain
    Last Post: 25th January 2006, 00:00
https:www.vectra-c.comforumshowthread.php90644-Flat-Spot-Stutter-or-hesitation-on-2006-1-8-VVTi-SRI
2006 vectra flat spot opel astra h z18xer bad acceleration and hesitation wen coldvectra c hesitation on accelerationvvti stuTtering problem 1.8 vvti hesitationastra 1.8vvti flat spotastra 1.8 vvti sps updateastra h hesitation on accelerationvectra c 1.8 vvt hesitationastra h 1.8 vvti throttle problemastra h 1.8 vvti hestiation in 2ndastra h 1.8 vvti hesitation in 2nd gearz18xer flat spot 4 000z18xer flat spotvectra c 1.8vvt flat spot when coldastra 1.8 vvt flat spotastra h flat spotvectra c sri 1.8 stutteringvectra c 1.8 hesitation on accelerationz18xe hesitationvectra 1.8 hesitationvectra c 1.8 hesitationvectra 1.8 vvt hesitation when warming1.8 kseries slight flatspot on accelleration
