Results 1 to 10 of 16
Thread: Serious Problem with Vectra
    Mar 2009
    Northern Ireland
    Default Serious Problem with Vectra
    My Girlfrind has 2004 Vectra.
    This morning it died on here while driving.
    A few things happened.
    • The Anti lock Brake system light and Electronic Stability Program lights can on
    • Then the Engine management light came on
    • the then power steering light came on and power steering stops working
    • While all this was happening she noticed that teh temperature gauge was in the red
    • then the oils pressure lights, battery light and brake system lights came on
    • then it died
    If you leave it a few minutes it will start again, but sooner stop again.
    Does anyone know what is wrong?
    Mar 2006
    Belfast
    At a guess, either earth strap loose, or the alternator has died.
    Mar 2009
    Northern Ireland
    Forgot to mention that the power steering also stops working when the light comes on......edited previous post to included that fact
    Wsa thinking that it was an alternator.....but would that be the problem when it runs OK or a while?
    Regular Member JSYSH466Y's Avatar
    Newcastle under Lyme
    Hopefully nothing major it does sound like an earth problem or a short. Have you had any work done recently which may have chafed wiring?
    At a push could the immobiliser be causing problems?
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    Question
    ZS,
    How did you up your 140BHP VVTi to 160?
    Mar 2009
    Northern Ireland
    It was serviced about 2-3 weeks ago.
    If it is and earthing problem where is the best palce to start looking for the problem?
    There are usually several earth points the main one is close to the battery, Engine block has a few and each motor usually has one. I would try and follow from the alternator if poss
    Mar 2006
    Belfast
    Quote Originally Posted by KSD View Post
    ZS,
    Blew the engine up at 20k, got it rebuilt under warranty. Otherwise totally standard.
    Quote Originally Posted by Keeks View Post
    Everything you list including the power steering is electrically operated. Definately sounds like there's a bad connection somewhere.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    check your batt terminals are tight m8.
  1. Problem...? Vectra SXI...problem with starting after filling with fuel?
    By doozer in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2022, 12:25
  2. Vectra wiper problem - any advice appreciated - Vectra C
    By newbreed in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2011, 20:57
  3. Vectra 1.8 LS, big problem?
    By Mattyreid9 in forum Engine & Drivetrain
    Last Post: 5th October 2010, 12:28
  4. air con problem vectra c
    By stevenrwaller in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2010, 10:03
  5. vectra c problem help
    By beemerboy31 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th January 2009, 23:39
