Results 1 to 10 of 22
Thread: Diesels really don't like being run empty do they!!
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Default Diesels really don't like being run empty do they!!
    Sick of my life today! Battery carked it, so I went and bought a new one, took it home and fitted it only to find that although it's exactly the same size as the GM one, the clamp won't bite so although it can't come up or down, it can slide front to back.
    Decided to live with it for now and look into options about bracing it, a post on here said there's a clip that clips into the battery box to stop the battery sliding, so that's a good thing!
    Decided to try starting it, immediately burst into life - happy days so shut it off to tidy up, went to start again and crank, crank, crank...
    I knew the fuel was low, as it was flashing the light at me but prior to the battery swap, the range to empty reading said 30 miles. It was only after the battery swap that it popped up saying "Range 0 Miles"... Cue a trudge to the petrol station... Joy!!
    Stuck 5 litres in, let it prime and crank crank crank, nothing (although the pump sounded like someone who hasn't eaten for a month, it was gurgling and rumbling and generally protesting like mad). It also thought now would be a good time to tell me about low fuel rail pressure... y'don't say. Well done, car!!
    Eventually got it going, drove it as gently as I could to the petrol station and got enough fuel in to make the gauge actually respond, as sod's law would dictate though, it went up to 1/8th of a tank while I was sitting waiting, still showing Range 0 Miles...
    I think from now on, the Range Meter will be known as "that lying little ******* who lives in my dashboard!!"
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by BoostPuppy View Post
    No
    Oct 2008
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    There should be a little block that sits in front of the battery that can be pulled out and then moved if the battery is smaller. It even has the corresponding battery sizes written on the bottom of the battery tray
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    My tray has the sizes written on it, but no little block... That's the bit I need!!
    If yours has one fitted John, any chance of a photo of it so I know what I'm looking for?
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    34 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    sorry for the bad luck mate but funny write up thanks for the giggle
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    You've probably sucked all the crap from the bottom of the tank into your fuel system as well - I would consider changing the fuel filter
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Yeah I was thinking the same thing, I'll see how it goes - if it starts protesting again, I'll be getting my hands dirty *again*!
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Year : 2008
    Mileage : 31000
    Quote Originally Posted by alcutler View Post
    and probably damaged the fuel pump with no fuel going through it
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    I must admit, that is something I hugely doubt!!
    Oct 2008
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
  1. performance diesels
    By stephen g in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2010, 18:29
  2. i know diesels not for everyone
    By satbeychap in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2008, 16:16
  3. bmw 320 diesels
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2007, 12:21
  4. diesels
    By chris_20 in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2006, 23:19
  5. Calling all Diesels
    By AJA in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2006, 22:22
