Anybody know what these fault codes are 1614,1616,1613.I did the brake and accelarator thingy and came up with these.
P1613 = Immobiliser no or wrong signal
P1614 = Wrong transponder key
P1616 = CIM wrong environment identifier
If they are the faults, it looks like someone changed the CIM over from the original one and didn't get it tech 2'd into the car
It's where you hold down the accelerator and brake then turn your car on (not start ) and you can read out your fault codes. Works for the 3.2 Veccy C and the 2.6 Veccy B. Link to thread here. http://www.vectra-c.com/forum/showthread.php?t=44548
I see,
Doesnt work on the 2.2 though
surely if it had not been tech2 the car wouldnt do anything ie dash etc.
Have you had any problems starting the car?
Yep sometimes the padlock symbol comes up on the dash and the car is dead (imobiliser no cutting in)i have to keep putting the key in and out and eventually it will start.I have also noticed that when i put the key in the ignition and the padlock symbol shows if i then press the unlock button on the fob the car will start.
