I have a chattering noise coming from the turbo i think? But only when its cold, it does happen until i drive it. but when it warms up it goes.
Is this normal?
Please help!
Is this normal?
Please help!
mine makes a whooooosh noise when i change gear.......
Sounds like the bearings knackered. As the bearing heats up and expends, it is less noticable.
A turbo rebuild may be needed
You could try removing the inlet hoses to the turbo to see if there is any play in the shaft. There should be very little to no movement.
Duncan had his rebuilt in his 2.0T. have a search for his thread or drop him a PM Turbo technics did the work for him.
