Results 1 to 10 of 16
Thread: Outside Temp Sensor
    Jan 2011
    Kent, England
    Vehicle : Vectra C
    Trim : SRi 140bhp
    Engine : 1.8
    Mileage : 60,000
    Default Outside Temp Sensor
    Hi guys, a couple of days ago the outside temp display in my 57 reg 1.8 SRi started just showing an 'f' and nothing else. Searching this site gave me the idea that it could be the sensor so I looked around and got one off eBay, item number 190430484589, which had loads of compatible Vauxhalls listed. When I tried to fit it today the display is still just showing 'f'. Is there anything else that could cause this problem or is it more likely another duff sensor?
    Thanks in advance
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    I have replaced mine a few times now, I reckon my wiring into the plug that connects to the sensor is iffy so will be looking at doing a new soon. Wiggle the wires by the plug to see if yours cpmes to life.
    Jan 2011
    Kent, England
    Vehicle : Vectra C
    Trim : SRi 140bhp
    Engine : 1.8
    Mileage : 60,000
    TY I'll give that a go in the morning before work, and before i contact the seller to complain about him sending a duff sensor
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    Quote Originally Posted by Caveman_nige View Post
    Mine was reading about 8 degrees to warm.
    Turned out the main plug the bumper wires go through (Temperature sensor and fogs) had a bit of moisture in it somehow and the temperature pin was green.
    So a quick clean with some wet and dry and a spray of contact cleaner in the other half and its all fine now.
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Lee have can you point me to this 'plug' please as i really want to sort mine out once and for all. Thanks
    Jan 2011
    Kent, England
    Vehicle : Vectra C
    Trim : SRi 140bhp
    Engine : 1.8
    Mileage : 60,000
    Its on the lower grill, passenger side roughly inline with the edge of the number plate. I got to mine by going behind the bumper just in front of the passenger wheel because I have the under tray fitted.
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    lol I know where the sensor is bud, as stated above i have changed it mine a few times now.. Its the particular part of the wiring loom where Lee found a corroded connector that I want to sort out as that is the weak point..
    you will find that this is probably what is causing yours to go stupid as well
    Jan 2011
    Kent, England
    Vehicle : Vectra C
    Trim : SRi 140bhp
    Engine : 1.8
    Mileage : 60,000
    Ahh apologies :0) its too early in the morning lol
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    In the same loom as the fog lights.
    Its right next to the nearside fog light connector:
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    yeah thats the sensor, but was those wires in that plug that you cleaned up or somewhere else further back along the wires?
  1. Outside temp sensor
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2018, 03:02
  2. Outside Air temp sensor........
    By Mark@Elite in forum Vectra C / Signum Troubleshooting
    Last Post: 4th February 2012, 16:20
  3. Temp sensor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 21:23
  4. Outside temp sensor
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 18:29
  5. Temp Sensor
    By ghostrider in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2006, 22:45
