Results 1 to 9 of 9
Thread: CDTI query with oil levels...
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Default CDTI query with oil levels...
    Hi all
    Done almost 5k in my car since purchasing it & havent had to touch the oil atall. It's always read full on the dipstick since taking ownership of it.
    Around a month into owning it, the engine developed a ticking noise, the noise cars make when the oil hasnt circulated enough when you first start it. Comparable to the tappety sound an old fiesta makes.
    I straight away checked the oil level & still it read full (Tried with a hot and cold engine)
    Thought nothing of it then on the way to work today the oil low light came on the dash - Balls, I thought.
    Stopped on the way home from work & got some oil, checked the level & low and behold, full.
    Put some oil in regardless just to make sure I wasn't getting a false reading & the light is now off again. Ticking is still there though.
    So my question is, can the dipstick give a false reading? Or is my oil level sensor knackered?
    It's a 2004 Preface SRI 150, with 81k on it.
    Cheers
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Oil light will light with low pressure too. That would also explain the tapping!
    Regular Member AntSSSS's Avatar
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Year : 2008
    Mileage : 100k
    Remember when checking the oil level on a cdti you need to:
    get the engine to full operating temp
    turn the car off on a flat surface
    wait 5 mins
    dip and check
    That is the process for the cdti. If you check when cold etc you can get falsified readings.
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Quote Originally Posted by stevoxsi View Post
    Interesting, could the oil pressure be checked via vauxcoms cheaper brother?
    I really don't want to spend £100's on a new oil pump!
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    So this is the ticking noise..
    http://s1279.beta.photobucket.com/us...89406.mp4.html
    I am right in thinking thats quite a bad ticking appeared, it's not just my imagination is it?
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    Quote Originally Posted by JJ0063 View Post
    Sorry, going to have to pass on that! Never tried, nor do I have either!
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    No worries. I'll have a go.
    Can you view the vid? What do you think?
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    Can't watch it on my phone. Just started nightshift, but I'll have a look in the morning!
    Feb 2010
    Wirral
    10 Post(s)
    Trim : Design
    Engine : 1.9CDTi
    Mileage : Lots
    These engines have hydraulic tappets - just sounds like a noisey tappet to me. I would definitely get the oil pressure checked though - wouldn't be hard for a garage to stick an analogue gauge on the pressure switch connection. Remember if the pressure switch has failed so it's reporting the incorrect pressure and bringing the light up it won't matter what scan tool you use to look at the pressure, it'll be wrong. Get a proper analogue gauge on it.
  1. CDTI inlet manifold query !
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 14:19
  2. Oil levels.
    By nokiaman1978 in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2010, 14:42
  3. Noobie Here, 1.9 CDTI SRI Query
    By agreen0 in forum Introduce yourself.
    Last Post: 30th December 2009, 20:22
  4. 1.9 CDTi Servicing Query
    By brianrh in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2008, 07:57
  5. vectra-c.com levels
    By aaruck in forum The 'Off Topic' room
    Last Post: 20th June 2008, 01:56
