Results 1 to 10 of 16
Thread: SXI front springs
    Regular Member AL21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    7 Post(s)
    Vehicle : Toyota Aygo
    Trim : x-pression x-wave (nav)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 13400
    Default SXI front springs
    Hey guy's,
    I've just taken my veccy c into my local vaux garage for a check-up, they spotted 2 broken front springs (among other things), what springs will I have on the car, the vaux sales guy said that they don't know what springs I will have on the car (sports sri/standard) as it's the SXI, they had to physically remove the springs from the car and look at a coloured tag to tell the difference between the
    two. . . .
    My question first being, is this complete bo***cks to get me to give the car to them to do the work . . . or is there actual truth behind this?.
    Secondly, does it matter which springs I put on the car to replace the broken ones, if they are the standard ones, I'd like the sports/sri springs fitted as there the same price.
    P.S, it's a pre facelift 53 plate sxi
    AL
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    mine is a 54 plate and it has sri spec sports shocks and springs fitted as standard
    i changed it as my 2 front springs snapped for a set of pi springs 45mm front and 40mm rear, looks a treat now
    Regular Member barkzz's Avatar
    I had a 53 plate SXI, and it had sports shocks, but standard springs, apparently though the SRi lowered springs are only an extra £5ish per corner
    Jun 2007
    7 Post(s)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 13400
    I've been looking at LMF, their price for a full set of lowering springs, (front and back) are the same price that vaux quoted me for just the front two, is it worth getting a set of 30mm lowering springs for the car or will it mess up the car?
    Looking at these,
    http://www.lmfvauxhall.co.uk/store/p...at=2286&page=1
    AL
    Quote Originally Posted by al21784 View Post
    Looking at these,
    AL
    Well obviously with new springs on, you will more than liekly need the tracking re-doing. But i cant really see a problem.
    Only thing i would be thinking about is the shocks on the front, i.e. any difference in length, that could cause issues fitting smaller springs.
    Jun 2007
    7 Post(s)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 13400
    Quote Originally Posted by barkzz View Post
    Well obviously with new springs on, you will more than likely need the tracking re-doing. But i cant really see a problem.
    Aye When I get the springs done, my mechanic is doing the track rod ends , he's said it will need laser aligning after the work has been done, so I'm prepared for that one
    Spoke to LMF this morning, they say there a direct fit/swap
    AL
    Mar 2009
    loughborough
    Answer to your first question is that they are telling you the truth.
    The springs have coloured paint on them, I have seen yellow on standard springs and green, green, white on sports springs, you should be able to see the paint on the spring usually on one of the coils, this paint tells you what spring you have.
    Jun 2007
    7 Post(s)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 13400
    Quote Originally Posted by clive3373 View Post
    Thanks, may be worth a look see
    AL
    AL
    Excellent news, time to lower your ride then! Pics when done?!
    Jun 2007
    7 Post(s)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 13400
    Aye mate , I need some new springs and it seems only logical step . .. . . and dear god yes!
    AL
  1. Are front springs different..?
    By Chunklamb in forum Suspension, Wheels & Brakes
    Last Post: 1st September 2012, 20:47
  2. front springs
    By porthy-t in forum Handling & Braking
    Last Post: 13th May 2009, 18:41
  3. front springs
    By iceeee in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2009, 09:25
  4. Front springs
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2006, 10:48
do i need sport springs on my sxi
