Thanks Thanks:  1
Likes Likes:  4
Page 8 of 8 FirstFirst ... 678
Results 71 to 74 of 74
Thread: 1.9 CDTi Swirl Flaps - What, Where, Why and How Much?
  1. #71
    Nov 2016
    Orkney
    Trim : SRI Estate
    Engine : 1.9 cdti
    back to square one did the brass flap bar mod about 10,000 miles not bad but it's off again can't decide if I should get another set of brass fittings or what ?
  2. #72
    May 2020
    Milton Keynes
    Engine : 1.9 cdti
    Quote Originally Posted by BIGMJA123 View Post
    Looking in my engine bay tonight after doing the front bulbs I have realised my swirl bar is off... after reading all
    the comments on here it looks a big job..
    didnt run car as I wasn’t sure but I’ll check tomorrow
    Looks hard than it is
    I done mine not so long and worth doing but as long as you car as no engine light on you can just leave it
  3. #73
    May 2020
    Milton Keynes
    Engine : 1.9 cdti
    Quote Originally Posted by ep1centre View Post
    Alright, you got my attention... cheaper is better when it comes to a daily runabout, so suppose I decide to either weld or otherwise blank mine or buy a blanked one, presumably the car still runs so that i can get to someone in order to map it out.
    How would I go about finding someone local (ish) who would map it out and what are (roughly) the costs involved in doing so?
    Also who supplies and fits them for £160?, after a quick look on ebay the manifolds alone cost £220... there are some blanking kits for £30 so i suppose i could blank mine myself.
    Euro car parts sell the blanking plate
  4. #74
    May 2020
    Milton Keynes
    Engine : 1.9 cdti
    Hi Alan,
    Thank you very much for your reply - do you have any recommendations on a how to or video showing how to do the alternator without the manifold, I ask because if that's the case, it can be done without removing the manifold, I might decide to do it at a different time.
    Re the manifold, I think I'll still replace it with the standard parts (ie with swirl flaps) I've messed around with cars a lot in the past and I found from personal experience that modifying something from original spec always leads to more hassle than it's worth. In this case for example I need to find a welded manifold, then find someone to map it out and find the time to go see them and I have a nagging feeling that there's bound to be other knock on effects (poor / different running of the engine, worse fuel consumption, etc). My theory is, if this manifold and swirl flaps have done their job for 180k and i replace them with new parts now, they shouldn't cause me anymore problems for as long as I own the car...
    Just to confirm then, no wearable parts on the swirl actuator that would warrant replacing it as a "serviceable part" at the same time? - essentially if it works, leave it?
    Thanks again
    You don’t have to have the Matt out if you just leave the black control box plugged in at the back of the engine but remove the linkage arm from the control box
  1. Swirl Flaps what year? 1.9 cdti
    By caigey in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2013, 20:50
  2. CDTI swirl flaps sticky?
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 13th March 2013, 19:36
  3. cdti 120 swirl flaps
    By jymercer in forum Engine & Drivetrain
    Last Post: 12th August 2012, 00:12
  4. Cdti swirl flaps
    By rob1981 in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2012, 07:29
  5. Swirl valve flaps on a 150 cdti
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 19:37
1.9 cdti swirl flap symptoms
https:www.vectra-c.comforumshowthread.php184055-1-9-CDTi-Swirl-Flaps-What-Where-Why-and-How-Much
vectra cdti swirl flap symptoms
cdti swirl flaps
P2279 opel zafira
p2279 z19dthvectra 1.9 cdti swirl flapsvectra c swirl flapsOpel P2279vauxhall swirl flapsp2279 opel 1.9 cdtip2279 opeloperation of swirl flaps on vauxhall saab turbo diesel engineshttps:www.vectra-c.comforumshowthread.php184055-1-9-CDTi-Swirl-Flaps-What-Where-Why-and-How-Much#::text=Cause:- Charge air pressure going to cost to fixswirl flaps vauxhall zafiraastra swirl flapsswirl flap failure symptomsz19dth swirl flapsSwirl flap symptomsvectra 1.9 cdti 150 manifold problemsswirl flaps vectra cp2279 astra h 1.9cdtip2279 zafira z19dthvauxhall astra twirl valvesvectra throttle body gasket 1.9 cdti site:www.vectra-c.com
Tags for this Thread
