Thread: Signum Boot Light!
    Regular Member maurauth's Avatar
    Southampton (Locks Heath)
    Default Signum Boot Light!
    Does anyone know how to get to the boot lights in a facelift signum?
    I bought the car with both presumably both bulbs blown. Any ideas on how to replace the bulbs? I know that they're festoons and I've got bulbs that will fit I just can't work out how to get to them. Do the light holders push out, or do you have to reach round behind and fumble with them.
    I've tried everything I can think of. Tried taking the tail light clusters off but still no access from there.
    Gah, thanks if anyone can help!
    Full Member paul.sessions's Avatar
    leighton buzzard
    dont know about signum but the vec the boot light just pulls out of the carpet try a small flat bladed screwdriver
    Nvm, sorted it now, the bulbs weren't even blown. Some spanner had just unplugged the bulbs on each side.
    In case anyone is searching for this post in like six months time, you can get them out by reaching in behind and pulling the plastic from the rear of the car towards you and the housing will pop out.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by maurauth View Post
    Common action by dealers... on the forecourt, boot open all day.... many tape down the pinswitch, some remove boot bulbs, fuses, others unplug lamps to save the battery. Should have been checked and reconnected during pre-delivery inspection.
    Quote Originally Posted by Handyandy-UK View Post
    mmm, quite a few things didn't seem to get properly done at pre-delivery inspection, car wasn't really washed properly outside and inside seemed like they just gave it a dust, hoover and sprayed some air freshener.
    Full Member Big Sig's Avatar
    Just means you can do it correctly yourself
    London
    The boot light in my Signum stays on even after the car has been locked. Seems to go out after about 5 minutes. If this is a 'design feature' I cant imagine why they would have done it. But it might also explain why you found they were disconnected. There are also some threads on here from people who dont lock their car when secured in a garage then find they have a flat battery.
    Quote Originally Posted by clivep View Post
    My boot light definitly goes off when it's shut- as I've fitted LED strips now which you can tell very easily that they are on or off. Maybe someone has fitted some sort of capacitor or something in your boot light circuit so they stay on- maybe they worked with their boot open a lot - used the signum as a tool carrier or something?
    Hanging Heaton / Batley
    20 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Unclip the wires from the light, and connect the block round the other way bud...
    You've connected them the wrong way thats all, easy mistake...
  1. Led for boot light
    By Knight Rider in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2012, 17:00
  2. Boot light?
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2012, 14:19
  3. boot light
    By chrosty in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2011, 09:11
  4. Signum boot light - how to, where to?
    By Rog-the-dodge in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2011, 15:08
signum boot light on
