Results 1 to 10 of 15
Thread: Can I Replace Fog light Bulb for a 100 watt Bulb
    Regular Member m300raj's Avatar
    Nov 2009
    Hampshire
    Default Can I Replace Fog light Bulb for a 100 watt Bulb
    can i do this without causing any faults?
    thansk
    Mileage : 000
    I see no reason. Other than the road legal side of it. But I would not recomend it as the higher power drain could melt the wiring and cause untold damage.
    Regular Member neilybhoy1888's Avatar
    caithness
    i had 100w bulbs in my fogs and i went thro 4 bulbs (2 sets) in about 3 months if you want better bulbs in the fors go for nightbreakers thats what i am running now and they are brighter than the 100w bulbs and will last longer
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Plus problems with bulb holders, lenses, reflectors melting and cracking.
    If you really want to you can fit hid's
    caithness
    i want hids in mine lol
    May 2007
    West Yorkshire
    I can't remember the last time I used my fogs (I would only use them legally) so I would not benefit from any different bulbs.
    Nov 2009
    Hampshire
    I am going to fid Mtec 100watt bulbs as my factory fit headlights are hid and the fogs look to creamy
    May 2007
    West Yorkshire
    But how often do you use them?
    Nov 2009
    Hampshire
    At leat onece a week depending on time of year as it is foggy where a live in the mornings and late at night and i anm out in the stick a bit where it does tend to roll in
    Nov 2009
    Hampshire
    Now done, this is not easy to do you have to remove the large shield under the car and the you have access to the bulb
    before and after pictures I also drilled holes in the fog light covers to stop condensation
  1. bulb out light
    Last Post: 16th April 2012, 21:35
  2. Bulb Out Light On :@
    By Tam80 in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2011, 10:32
  3. Osram's Hyper H7 clear 65 watt bulb - Where to buy
    By TowerMan in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2009, 13:26
  4. Fog light bulb
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2009, 23:25
https:www.vectra-c.comforumshowthread.php99983-Can-I-Replace-Fog-light-Bulb-for-a-100-watt-Bulbpage2
