Thread: 3.2 v6 - is this normal
    Jan 2010
    UK
    Default 3.2 v6 - is this normal
    Hi All, my first post so please be nice
    Bought a 60k mile GSI in November with a couple of issues i'm working through - these cars are bargains!
    Can you confirm if it's normal for these cars to do this:
    1. Engine whine, almost like a quiet electronic beep or supercharger whine, at high revs.
    2. Temperature gauge, engine takes 10-15 minutes to warm up and seems to get hotter under hard acceleration, will be changing the stat today.
    3. Vibration from steering wheel from 50-70mph, seems ok at 80 (?!?!?). Suspect usual balancing issue.
    Thanks in advance guys
    Tom
    SAUCHIE
    not sure about whine. a petrol engine should run about 85 no matter what. if your in town it will run hotter and fans will kick in from time to time so might be worth your while changing thermo as there a known failure issue. the vibration sounds like a wheel balance problem. try getting them balanced if this doesn't cure it i would check front wheel bearings next.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    1. No
    2. No
    3. Balancing as you suggest
    Mileage : 000
    Quote Originally Posted by gtr1000 View Post
    1. No
    2. No
    As just said.
    The whine might be a bearing being driven from the auxillary belt or even a cambelt pully, might even be a bearing in the allternator,aircon pump.Might be a waterpump bearing too.
    Jan 2010
    UK
    Thanks all, i'll be replacing the stat if it stop raining for a few hours!
    The 'supercharger' sounds like it's built into the dashboard, and doesn't sound like a bearing to me. I'm wondering if it's the brake servo leaking but don't know enough about how they work to confirm and don't fancy taking the dash apart unless i'm 100%. Has anybody here had to get to the servo before?
    Thanks for the input
    Tom
  1. Normal or Way Out?
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 19:22
  2. is this normal ?
    By bigbranno9 in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2012, 10:41
  3. is it normal
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 4th January 2012, 22:24
  4. Is in normal?
    By Pulja in forum Diesel Engine related
    Last Post: 28th June 2011, 20:20
  5. ...Is this Normal??
    By adam_starkie in forum Engine & Drivetrain
    Last Post: 3rd February 2011, 18:58
