Thread: Gearbox Problem
    Apr 2008
    Belfast
    Default Gearbox Problem
    Hi all, just need a bita help!! Car had a new clutch ect put in a few months ago.. The last few days the car has been really hard to put into gear. Its not 'crunching' or anything, just really stiff. My brother thinks it might need blead what ever that means
    Anyone any suggestion what it might be? Could it need gearbox oil?
    Thanx in advance!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is every gear difficult, or just the low ones - ie first and reverse? Does the gearbox 'drag' when in gear? ie select first with clutch fully depressed, remove handbrake and does the car try to pull forwards when it's on level ground?
    If so, it would seem likely that the clutch isn't disengaging fully and could either need bleeding, is defective or (rather stupidly) is the carpet restricting clutch pedal movement?
    If these are not the case and all gears are difficult it may be that the gear cables / selectors need adjustment. I seem to think there is some info on here about that. Or could be a worn joint or bush in the selector mechanism.
    (Bleeding means to get all the air out of the clutch hydraulic circuit, air compresses and reduces travel of the release mechanism of the clutch - same as brake system) - I would have thought that if the clutch wasn't disengaging properly it would cause gear selection crash, especially for reverse..... but maybe not if it's only mild.
    Low Gearbox oil doesn't normally impact of selection, unless it is chronic lack of oil.
    Apr 2008
    Belfast
    My bad.. just noticed I posted this in wrong section
    Ste, thanks for reply. Its thru all gears, will just get it to mechenic on Monday
    Oct 2009
    Machynlleth
    Sounds like it needs bleeding, had the same problem with it no engaging any gears on mine a couple of days ago, £20.00 later after they bled it, works fine now.
    Pump the clutch pedal a few times, if it does go into gear after that it could be air in the system.
    Mileage : 000
    I have poped it in the correct section for you.
  1. Gearbox problem? Help!
    By Gubmint Agent in forum Engine & Drivetrain
    Last Post: 7th February 2012, 23:45
  2. gearbox problem
    By vectra sri dan in forum Engine & Drivetrain
    Last Post: 18th May 2010, 17:56
  3. Automatic Gearbox problem
    By tomhrb in forum Vectra C / Signum Troubleshooting
    Last Post: 4th June 2009, 16:54
  4. af23 gearbox problem
    By azn_007 in forum Engine & Drivetrain
    Last Post: 16th January 2008, 00:06
