Thread: Signum 2.2 direct petrol. Timing Chain
    Jan 2010
    Glasgow
    Default Signum 2.2 direct petrol. Timing Chain
    hi
    new here so apologies if this is a stupid question
    my 2004 signum has never had the chain replaced, it's got 33K on the clock - i know these things are bad for snapping, should i be getting it replaced soon?
    also what should i expect to pay for this should it need done ??
    thanks again !!
    Regular Member benny's Avatar
    Feb 2006
    dudley
    hello the direct can suffer from chain problems but no where near as bad as the z22se go to www.z22se.co.uk for more info .....hope this helps benny
    Full Member
    Bristol
    The 2.2 petrol engins around 2001 failed due to incorrect oil feed to the chain. Any 2.2 after that time will have the modifed oil feed as yours is 2004 , you should get around 200k before it need changing. Auto data does not show any change intervals. Like bmws which are all chain does not need changing until it rattes.
    Jan 2010
    Glasgow
    excellent cheers guys!
    Wales, UK
    Are you familair with engines? replaced mine myself whilst I did a head gasket change. Its not the most difficult job.
    Jan 2010
    Glasgow
    Quote Originally Posted by mark_647 View Post
    unfortunately not : (
    just with the car now well over 5yrs old and a nightmare last week with the exhaust (all good now though) i just wanted to be checking if there is anything that should be getting done and timing belt/chain is an obvious one that i should be checking....
  1. 2.2 direct timing chain
    By Paddy in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2012, 21:31
  2. 2.2i direct timing chain
    By LEEROB695 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 22:10
  3. Signum 2.2 direct petrol. Timing Chain
    By barneyp06 in forum Engine & Drivetrain
    Last Post: 17th January 2010, 12:28
  4. Timing Chain 2.2 Direct
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 15th January 2009, 10:59
